gingerfold:
Saviem:
Hello all, simple fact, UK useage was far more intense in terms of utilisation, ton miles, and speed, than the rest of Europe. The Swedes could not believe what we did with the little F86, but it was perfect for 32ton operation, 192hp, legal 22ton payload, so manouverable it was untrue and economic, a gaffers and drivers motor all in one!! Can anyone suggest another that has fulfilled that role since?? Cheerio.For ‘intense’ read skinflint guvnors using underspecced,gutless,uncomfortable wagons to do more work than they were designed for.The role has’nt been fulfilled in recent years because Brit guvnors were finally dragged kicking and screaming into the real civilised world starting with trucks like the F88,DAF 2800 and F10/12.
Yes, “skinflint guvnors” there were. And it’s still the same today with regards to the intensity of operations. With road haulage margins being so slim you need to get maximum utilisation out of your vehicles. At the company I work for we currently have a double-shifted trunking vehicle working 7 days weekly covering 5,650 miles every 7 days. The modern terminology is ‘sweating the assets’.
That’s nothing new I was doing 400-500 mile trunks per shift before speed limiters but there’s no way that you could get that type of productivety with the average speeds provided by the type of power outputs that most British guvnors were speccing during the 1970’s.
It was the likes of you Carryfast that carved the job up.Starting the rate cutting by doing your 400-500 mile sprints as you call them.The demise of a good paying sector of the British haulier is down to drivers like yourself not the Guvnors
Cheers Dave.If you think that was fast you should have seen how quick some of the other firms like Independent Express were going using even faster wagons.
I never said it was fast.I said you were carving the job up
Those were the runs I was given and those were the mileages and running times required and if I had’nt have done those runs as required there would’nt have been any ‘job’ because I’d have been down the jobcentre looking for another one.I never said it was ‘fast’ either but it was fast enough to make the job viable which was the difference between a Gardner powered Brit heap and a DAF 2800. ![]()
