I’ve had that oil feed O ring checked, there’s all kinds of weird stuff going on with it. The turbo replacement is not connected to the engine brake problem, or so they’re saying!
Now I’m not an expert by any means, but I know my way around an engine as I understand what each part does and all that knee bone connected to the thigh bone stuff, I’ve also owned lorries since 1994, so I’ve been under more than my fair share of cabs. I also ask fitters what they’re doing and why so that I understand why I’m getting such a big bill lol.
So I was due a service, I asked the head fitter at the local Volvo approved garage, who is a full on Volvo master technician if he advised a top end reset and he said he did, the engine had 480,000kms on it at the time, so in it went.
When I picked it up and headed out with a trailer I noticed my engine brake performance was bad, comparable with the exhaust brake on an F10 or similar. So I told them and took it back after that trip and they readjusted the top end again. I also told them I was using a lot of DEF (adblue) approx 3x normal use and that’s what led to the turbo being replaced.
It didn’t fix my engine brake issues though and as I said, there’s some weird stuff going on. It has a 3 position engine brake, position 1 is exhaust brake only, 2 is 50% engine brake and 3 is 100% engine brake, there’s no noticeable difference between 2 & 3 except I have more turbo boost in position 3, around 30psi to the 15psi in position 2. The boost gauge also flutters and as rpms build boost pressure decreases. So if I start at the top of a hill at 1600rpm with 30psi at 2000rpm I’m down to 15-20psi and the engine brake weakens as rpms increase, before it got stronger the higher the rpms went, as it should.
So now they tell me the next step is to replace the rockers and rocker shaft, but I’m not convinced, I don’t believe in coincidences, not in situations like this, the lorry was fine before they took the valve cover off and now it’s not.
I despair of it and it has far reaching consequences, if it turns out to be incompetence on their part then I won’t use them again, but I’m already boycotting the main dealer as they’re just a joke, I had that timing cover leak that started this thread fixed and had a weird vibration afterwards, I kept stopping to check it out and discovered that they hadn’t tightened the bolts holding the hanger bearing to the crossmember, so the prop was shaking around! They also trashed my cab, busted my phone charger, got grease on my seats and pinched the O ring on a fuel filter so it was losing prime overnight and I had to keep bleeding it, until I got my overalls on and started checking things out. I had a meeting with the service manager and after apologies he said he couldn’t get decent staff, not very confidence inspiring for a customer to hear!
So if this lot can’t sort this out, where can I go to get my work done? Nowhere, so it’s going to be pointless having Volvos if I can’t get them looked after.
