Finally got to drive a Proper Truck today
I was booked in for 4 hours of 1 to 1 training today with Capliano Truck Driver Training. 10 - 12 and 1 - 3.
My instructor was Ralf, Yes you can probably guess from the name hes a fellow European too. German to be exact.
He showed me round the truck i am training in. Its a Kenworth, With a HIAB . He went through the pre-trip inspection with me, after first showing me how to un-couple the trailer (first 2 hours was bobtail). After that I jump in the passenger seat, and Ralf drives me to some distant and quiet (under constrution) industrial estate about 5 minutes up the road from the school. On the way there he is explaining about how to shift gears, getting the timing’s right for gear changes, changing up and down etc.
Change up gear = 1700 - 1800 rpm , clutch - into neutral, release clutch, depress clutch , into next gear. This is all done in 2 seconds, so you count 1 for clutch in first time, 2 for clutch in 2nd time.
Change down a gear = get rpm to 1000 , clutch in and into neutral, build revs to 1500 , clutch in and into gear.
He kept telling me im cutting the corners too early (im bobtail remember, and i think he expects me to drive as if i have a trailer on the back of me). I just told him, ‘heh were bobtail, no need to use the whole road if we dont need to’ seemed to shut him up a bit.
We finally get to the stage where he is happy enough with my driving on the quiet roads, to let me drive in City traffic. This is where it felt really nice to be driving, actually with some traffic, and not going slow round the industrial park. We get back to the school, and go through the airbrake tests, then have a break for dinner.
1-3 pm. Watch out Edmonton - BigJon is in a big rig its trailer time.
So we start off by doing a pretrip on the trailer. making sure the wheels are chocked correctly. Ralf gets me to jump in the truck, and back the truck up so were just short of plate touching the trailer. I jump out and check the jaws on the 5th wheel are open, and we are lined up on the kingpin. Back in I get, Back the ttruck under so the 5th wheel is about a foot away from engaging with the kingpin. Now its time to hookup the airlines and electrical lead. I climbed up on the catwalk, and got to the lines , and coupled them up to the gladhands on the trailer, the electrical line is dead simple to connect (1 cable, no abs). Now i come to get down from the catwalk, and i dint quite make the little shimmy across needed to get round the hydraulic jacks for the Hiab. And end up falling off the truck, while still hanging onto the handrail, and my right foot still up on the catwalk lol (some of you may remember i fell off the back of my truck in Liverpool about a year ago and broke a few ribs. I thought this was gonna be the same all over again lol). Luckily im not injured at all, just look a bit of a prat infront of the other students.
I get back in the truck, and back the unit up until the 5th wheel engages with the pin and locks itself in place, This is all while holding down the Trailer brake valve in the cab. next is 1 tug test , to make sure im coupled. Then back out and double check that the 5th wheel is locked , and the jaws have closed. Next Ralf drives to the same quiet ind. park, explaining about the trailer cutting in, and making turns in the truck (Trailers here run at 55 ft, ontop of the tractor unit length.) . This is where it starts feeling like im a proper trucker again. Pulling a part loaded Flatdeck, with a huge concrete block, and a huge bag of gravel fastened to it. More driving around, getting used to the way the truck and trailer handle. then back onto the busy roads . We drive around for a good while, he took me along some of the test route, explaining about things that can catch you out while on test. Then we head back to the school, and its time to do my backing excercise (reverse into parking bay). I was surprised it was just a straight forward 90 degree reverse, no blindside , no s turn round a cone then into your parking bay like they test you in england. I messed my first attempt up, as i was expecting the trailer to spin round quicker than it did. did 2nd attempt looking out the window, so i could see where the trailer was going.
All in all a good day, Ralf said I have improved a lot since the first 2 hours this morning. But will need at least another 2 hours , to crack the gear changes, as im still occasionally crunching the gear change, and occassionally i miss a gear change, then it all goes pear shaped.
Im looking forward to tommorow, So heres advance warning, anyone near the Capliano area of Edmonton tommorow between 3 - 5, beware im on the road again (some of the other instructors say ive done well to get where i have in 4 hours re-training. must be doing good then )
edit: ill try to get some pictures tommorow of the setup im training in. ill also take some pics of the glad hands, (equivalent of suzies)
