I’ve not confused anything in a comparison between the detonation resistance of diesel fuel versus petrol.There’s no way that petrol can withstand the cylinder pressures and temperatures generated in a diesel engine without detonating unlike diesel fuel.Simples.
Hi Carryfast,
Blimey, this is harder than pulling teeth.
I:
Sorry Carryfast, but unless you quickly own-up to an honest mistake, (and you’ve got this one very wrong) then you’ve been rumbled.
A missed opportunity.
Yet again, you’ve introduced something that wasn’t being discussed. (Strike #2)
I didn’t comment in any way whatsoever on the subject of “detonation resistance.”
You said this:
LPG needs spark ignition so it’s not compatible with diesel engined trucks or cars
It quite rightly got shot to pieces, and you’ve completely missed more than one opportunity to own-up that you’re wrong.
Then you said this:
LPG and petrol both have an auto ignition temp.
Which is spot-on and correct.
Then I mentioned that if a person gets the meaning of ‘auto igniton temperature’ all mixed-up with the meaning of ‘flashpoint temperature,’ a person would start saying more completely untrue things like this:
But unlike diesel that temperature is far too low so it’ll ignite too early under compression ignition when the piston is still on it’s way up the cylinder on the compression stroke.
I also noticed that you’ve very probably got the definition of ‘flashpoint temperature’ confused with the definition of ‘auto-ignition temperature’ which is a basic and very common error. What you’ve said here would be spot-on if we were talking about flashpoint, but we aren’t discussing flashpoints because they are completely irrelevant to the subject at hand. The rest of your theories are based on TWO untrue premises and therefore fall flat the first time you post them.
I then pointed out that there is absolutely no linkage between ‘flashpoint temp’ and ‘auto ignition temp.’
Then I suggested that just because a substance has a fairly low flashpoint, it DOESN’T follow that the same substance has a fairly low auto-ignition temp.
Now then Carryfast, it’s fair to say that you have your detractors and they may have a point…
I’m undecided, so please humour me a little… please clarify this:
Now, just to be sure here… we’re not discussing the price of fish, nor what colour socks the postman was wearing this morning.
