dieseldave:
I was going to raise the issue of Cetane numbers of diesel in which lower Cetane means that it ignites slower at a higher point but detonates easier when it’s lit.
Hi Carryfast,
You were going to raise that, OK fair enough- go ahead and raise it, but be prepared…
Meanwhile, you also raised this, and it’s pure gold:
We don’t put spark plugs in diesel engines because they detonate diesel fuel using compression ignition under massive cylinder pressures and temperatures which would ignite petrol long before the spark does on a petrol engine.
You still don’t get the idea of a flashpoint temperature being VERY DIFFERENT to an automatic ignition temperature do you?
For the umpteenth time I have’nt confused flash points with auto ignition temperatures.‘But’ the issue of internal combustion is far more complex than just relying on one simple auto ignition figure,that’s assuming you’ve got the figures right anyway,and ‘detonation’ can occurr at any stage in the combustion process even ‘after’ ‘ignition’ of the mixture.I will though admit to sometimes having used the terms ignition and detonation in the wrong contexts and it’s ‘detonation’,not ‘ignition’ and ‘combustion’,that I’m referring to as being the issue if that helps.
So maybe now it’s time for you to do some explaining as to how an engine,which is designed to run on a fuel,which is designed to ‘ignite’ and ‘burn’ correctly (50+ ‘Cetane’),under massive compression ratios and temperatures,can run correctly on a fuel which is designed to be ignited by a ‘timed’ spark and which is designed to ‘burn’,not ‘detonate’,under far lower compression pressures (in this context LPG which has an even higher ‘Octane’ rating than petrol).
The argument seems to consist of those who are saying that we can ‘burn’ a high octane fuel in a diesel engine,under far higher cylinder compression and temperature levels than it’s designed to ‘burn’ in,whereas the ‘correct’ fuel is ‘supposed’ to have the opposite qualities of having a high ‘Cetane’ rating .
By the way if it’s all about auto ignition figures,and if those figures so far provided are correct,why would Brentanna have found it beneficial to start a diesel tractor on Petrol and not Diesel assuming that the Diesel ignites better at a lower temperature than petrol and what is the difference between trying to run a spark ignition petrol engine,at diesel engine compression ratios,on high octane fuel versus using the same fuel in a diesel engine regardless of how it’s ignited to start with .Suggest you ask a few engine manufacturers of the likely outcome of running an engine,at diesel compression/cylinder pressure levels,on high Octane petrol,versus high Cetane diesel,before using LPG in a diesel engine.
