newmercman:
bma.finland:
hello carryfast,what do you put up against the SCANIA V 8
  ,can,t wait, hej benkku
KW Aerodyne with an 8V92 in 475 horsepower spec against it’s 1970’s Scania V8 counterpart.
Apples to Oranges again
When you compare things you really need to compare like for like
You are also under the illusion that everyone used to run big power in the US, not the case, they didn’t run many conventionals either until the length laws were relaxed, Smokey and the Bandit films are not the definitive guide to trucking in the USA
There were big engined trucks around, but they were in the minority, just as you get people pulling boxes out of Felixstowe in 730hp Scanias and 750hp Volvos, you used to get the odd Yank with a big motor, most were bog standard fleet spec trucks with much less than 10hp per ton
Your own argument of the customer holding back development works against you when you cross the Atlantic, half of them would still be running Petrol engines over here if the Government would let them, because their Grandpa had one in the 30s
Even your beloved Detroits only managed to get a decent engine by default, a tractor manufacturer had made something that was too sophisticated for its own needs and handed it to them on a plate
Now you’re on about drawbars on KWs…WTF
Blimey nmm as I said before the only rules are that there are no rules.That is comparing like with like on the basis of V8’s and what was available during the 1970’s I also could have put a KW with a CAT 3408 into comparison the but two against one really would have been a bit unfair on Scania.
But if the Americans couldn’t sell them,because not enough people were buying them,you can bet those options would have been deleted and development wouldn’t have gone any further than the old Detroit inline 6 two stroke or the CAT 3406.But as we all know and for bma’s information in the real world the fleets,like everyone else over there,were calling for forced induction ■■■■■■■ engines and the V series 71 Detroits etc etc etc during the 1950’s and the rest is history and don’t remember anyone over there asking for the importation of Scanias or Scania motors because Scania could provide something with a better combination of reliability and power than what they had at home.
As for Detroit the fact is if it hadn’t have been for the fuel consumption issue and emmisions issue and had they just been a bit braver in going for the equivalent levels of electronic management and boost levels used by the four stroke opposition to date things just might look a bit different.But by the standards of the 1970’s,as I’ve said that KW with 3408 or Detroit 8V92 would have sorted out the Scania V8 no problem.But those issues of fuel costs and emissions are making all types of road going diesel engine development obsolete and I’d still bet on the idea of the relatively lower revving,relatively less stressed for equivalent output,spark ignition uniflow two stroke,running on alternative fuels idea,more than the big V8 four stroke diesel.So maybe grandpa might turn out right after all.
As for drawbars.Who else but a total closed minded artic beats everything else believer wouldn’t just put a box on the back of the blue and white cab over in the pics and then pull a drawbar trailer with it and why go backwards by not having the Aerodyne cab.
viewtopic.php?f=35&t=81994&start=210#p1280059
