240 Gardner:
Your spot on Chris as I could never see the reasoning for Seddons to fit the 8LXB de-rated to 200BHP in the 32/4 chassis. I believe the main reason was because they were using the DB 6:600 box which was patently useless behind anything more powerful than the 6LXB. I can painfully confirm this fact as we ran 3 220Cu Borderers with the DB box and they all suffered failures where as fitted with the Fuller RTO 610 box they performed faultlessly !
Cheers Dennis.
If I remember rightly, Dennis, they shoehorned it into a 9’6" chassis too!
The Cadwallader example looks longer though, but it was a year or two after the original announcement of that model.
I think everyone pretty much said the same about that engine/gearbox combination. Bowker’s fleet engineer used to tell me about the bearing problems with them behind the 220 ■■■■■■■ (and, to a degree, the 6LXB too), but he spec’d David Brown gearboxes for the double-shifted motors because some of the night men weren’t smart enough to tell the difference between a splitter and a range-change, nor indeed between their own botty and elbow, and kept doing damage by going down a range when they thought they were going down half a gear.
His illustration of the intellect of some of them was the example of one known as Catweazle: one night, Geoff takes a call from the West Midlands Police, to say that they have stopped one of the northbound trunk men on the M6 because his lights aren’t working. Geoff jumps in his car and drives down at speed from his home near Chorley, finds the motor on the hard shoulder and reaches inside the cab to try the light switches so as to decide where to start his troubleshooting. He switches on the master switch for the lights (on the back panel of the cab, because its an older Mk.1) and all the lights come on.
Nothing whatsoever wrong with the wagon - Catweazle just didn’t know where the switch was, and simply kept driving into the ever darker night! Of course, motorways were not usually lit in that day and age either. Now, Dennis, would you trust Catweazle with a range-change??
Come to think of it, you’d probably met him on the A5 or the A34 when you were nobbut a Brady’s trailer lad, eh
Hi Chris, Just read this post regarding splitter box and range change box, and it brought back a few memories. Like many, but not all drivers,
I had quite a few driving jobs when I was in my 20s. In 1973, I did just short of a year with Reed Transport at Wigan. For the first 6 months, I
was a spare driver. During the summer, I was on nights for about 6 weeks, on night trunk changeover, Wigan to Newport Pagnell on the M1.
Leave Wigan at 8pm, park up on Newport Pagnell southbound, walk over the bridge and meet the night man from Reeds at Maidstone and swap
keys, have 45 minutes rest and drive back to Wigan. Usually, if the southbound lorry was a H reg Scania 110 with a 5 speed splitter box, the
northbound lorry was a new L reg Scania 110 with a 10 speed range box, so you needed to be on the ball and remember which lorry you were in at
all times. The 5 speed box gear stick had a round knob and the splitter switch, and the 10 speed range box had a square knob on the gear stick
with a gap through it, and the range switch. I would drive with my left hand on the gear knob for most of the journeys, so at least I knew which
lorry I was driving. Not long after I started at Reeds, Les the Foreman called me in to the office and asked," Ray, Have you ever driven a Foden ?"
I said “Yes Les, I have driven a few”, I hadn’t drove a Foden, I was lying. Les told me that my work for tomorrow was a double deck load
of Corrugated for Kelloggs at Trafford Park which was arriving overnight from Reeds at Thatcham. Following morning, I got in an almost new
Foden, and had a look at the gear stick, 4 plus reverse on the knob, and a lever below the knob with 3 positions. 12 speed splitter box I thought.
I set off to Trafford Park and played many a tune on the gearbox, nothing seemed right. As I pulled into Kelloggs yard, I spotted an similar Foden
artic tanker of Tate & Lyle, so I spoke to the driver, an elderly chap from Liverpool, and told him of my gearbox problems. He asked “Is you gear
stick and switch like this one in my cab”, I said “Yes, its exactly the same”. He said, “We call it an 8 speed range box with an overdrive 9th gear”
The Foden drove like a good`un on the way back to Wigan.
Kind Regards, Ray.
