oiltreader:
:o![]()
Oily
oiltreader:
Stringor belt and braces
Oily
Iām assuming by the captions you gave those 2 pics, that you believe the Montgomery stack(trailers) to be less secure, and Macleod stack to be far better secured.
Iāll add some insight to this.
Myself and Muckles both done this type off work from Crane Fruehauf in Norfolk, many years ago, Iām sure he would concur with what I say.
Montgomeryās stack is new trailers, they have been stacked correctly with the middle 1 reversed, and the top 1 lowered at the front to drop the head board. There is only one concern I would have, that is that the forward most strap has been tensioned at an angle, If this strap had been secured just behind/infront of the running trailer landing legs, that would make for a perfect load.
To be honest we never used to secure the middle trailer as this guy has. We used to run stacks like this from North Walsham (Norfolk) to all over the Country, but the majority went to Boalloy in Congleton, Never in all the time I worked for that haulier(10 yrs) did any trailers come a drift, and we werenāt noted for hanging around.
Macleodās stack is old trailers, they need more securing, including packing under the landing legs, notice the upturned pallets and sometimes packing under the wheels too, depending on how crappy the floor is. the trailers could suffer from poor brake efficiency on the park brake, and or air leaks, so wheels chocks may be useful. Notice that as these trailers have no head boards, so they are stacked level.
Both these drivers have done a good job, at least from what I see in the pictures
As with so many things in this industry, there are loads of different nuances to what is effectively the same load
