tonyj105:
robert1952:
dave docwra:
Were the column change ones known as Romans & did these morph into MAN eventually.Romans were Romanian-built lorries with MAN F8 cabs. I think they did have column change, but that may have been coincidental. Someone will know on here. Robert
think it was an early version of ‘badge engineering’ , ROMANs were an earlier version of what MAN were producing at the time, I seem to remember a bit of a hoohar over the parts being interchangeable, you know , fit cheap ROMAN bits to you MAN instead of the pricey MAN bits. so they’d have had the column change , and that was a bleed over from the Saviems.
The Eastern Bloc countries often bought old Western European tooling and presses from obsolete (to us) models probably the most popular and best known being the Russian Lada which were Fiat 124 and 125s from the 60s. Serbia also runs some Mercedies Truck clones but I can’t remember the model number. Ref the MAN column change (to stay on topic) I drove an ex Shippams (the meat/fish past company) from Chichester one in the 70s and the linkage was well worn, ‘Lucky Dip’ was perhaps the fairest description, that was a ZF 6 slot + splitter.
 as they did regularly.
 as they did regularly. but later S40/S80 models they stuck the range shift switch on the gearstick, far nicer.
