Leyland marathon
TIDDERSON:
EDTRUCK:
I apologise up front if I am having a memory fade moment - didnt Pickfords Heavy Haulage run some Marathon 6x4 tractors with ■■■■■■■ 335 engines - any pictures to back up my vague memories would be appreciated. Im sure sammyopsite would know!!
Any good?
Pickfords had few 6x4 Marathons which were used as artics and as ballast box tractors Lincoln and Leicester depots had them and a few more but I had left when they arrived and I am sure there was one at Sheffield but it may have only been there temporally
cheers Johnnie :wink:
Hello from France :wink:
This is my brother’s Marathon 2 TL12, he is a carpenter
truck works perfectly (painted by me), it is mainly used for crane :
There’s not many left in that good condition…
Leyland Marathon cab tilted showing ■■■■■■■ 250 engine.
I have found this interesting article below which is well worth a read…
Mike Humble tells the story of the hugely influential Leyland Marathon
Marathon Down-Under!
I think ive mentioned this before , i could never understand why AEC never went down the same path as Scania, with the Marathon cab , if they lowered it they could have used it right through the range , in its normal form it wasnt far off being a walk thru cab so there was plenty of scope to drop it down quite a bit just like the 80 - 81 / 110 - 111 Scania cabs ,having said that it was `73 when it was introduced so they probably knew the writing was on the wall
South Wales hauliers marathons
2 brand new joints marathons
Hi Val74 ,that’s a real handy bit of kit ,I like the fly jib ,what size is the crane ,rear legs too ,regards Dan .
Hi, thank you :wink:
The crane is 25000 kg (55115 lbs) and with the jib length is 19 meters.
The winch on the jib is very convenient !
Not comparable with cranes nowadays, but goes well with the truck :slight_smile:
Marathon fans may like to know that on my LHD Seddon-Atkinson 400s thread, I have posted TRUCK mag’s July 1978 Euro Test which includes a Marathon 2 with LHD, TL lump and Fuller 9-speed 'box. Robert :smiley:
One badged as AEC but still a Marathon.
Stanfield:
210
It’s badged correctly then. Early Marathon sales brochures do exist with AEC badging.
Correct gingerfold the Marathon was engineered and built at the AEC factory Southall and later some were later produced at the Guy plant in Wolverhampton and at the 74 commercial show they were exhibited on the AEC stand they had the TL12 engine fitted an engine developed from the AV760
Stanfield:
I think the last ones were built at the Scammell factory at Watford , and some were fitted with the L12 engine for the oil companies
A few middle east spec marathons
That leyland marthon LNU 135 P driver is Colin Wright.
just a thought drove a marathon during my time at tankfreight was an all right motor but just a day cab i remember taking it somewhere to have a swing down bunk fitted to it when folded it folded up into the roof of the cab ! not the biggest cab cant remember where i had it fitted but sheer joy my first sleeper cab i was on shell chems at the time so pet regs no windows in the back just nice steel plates instead to freeze your ■■■ off in the winter these where the days before night heaters. Happy days think it was a ■■■■■■■ engine definately a fuller gear box it was replaced with a Y reg daf 2800 so a few years back
