gardun:
DonutUK:
gardun:
223
Buses, coaches and trams. Give priority to these vehicles when you can do so safely, especially when they signal to pull away from stops. Look out for people getting off a bus or tram and crossing the road.
Just checked again - no sign of MUST or even SHOULD. It is not a legal requirement. In fact it qualifies the advice with the phrase “when you can do so safely”. If I can, I will let them out. I AM NOT REQUIRED BY LAW TO DO SO.
However, if you fail to give way to a bus that is in the process of pulling out and collide with them, let me know how your argument holds up in court.
A reasonable, competent driver would be driving in accordance with the Highway Code (that is the courts view) therefore a reasonable competent driver will give way to those vehicles when they can do safely.
By the way, “safely” is not the same as “it’s going to delay me so i’m not going to bother with it” which so many of you seem confused about.
Maybe I’m playing devil’s advocate here, but I object to the suggestion that I do not understand the meaning of safely. (I don’t bother to go on about it here, but I am an IAM senior observer - I do understand safe.)
What would not stand up in court, in my opinion, is that a bus can pull into moving traffic with impunity and I doubt that anyone would consider prosecuting anyone who collided with that bus. The basic rules of the road apply to all vehicles and are not variable just because you are driving a bus. And before you bother - designated bus lanes are a totally different issue, not a different law.
A reasonable and competent bus driver should be aware that they do not have any right whatsoever, despite their deluded imagination, to expect traffic to give way automatically. I am still waiting for any indication that there is any legal case to support this delusion - THE HIGHWAY CODE IS NOT LAW however sensible it may be. I think you would find that a bus driver causing an accident by pulling into moving traffic will be prosecuted and not the driver of the vehicle with which they collide.
First point - they are not pulling out with impunity, they are indicating to leave a bus stop, other road users are choosing to ignore the rules of the road i.e. the Highway Code, so they have to resort to using their vehicle to influence other road users behaviour EXACTLY how they were taught to do. Where the problem lies is not with the bus driver that pulls out directly into the path of an oncoming car, but where the bus is already half way out of a stop having seen a gap where they can pull out into, and the car driver then refuses to wait, or worse speeds up, and tries to go round the bus as it is pulling out. In this instance i would like to see the motorist defend their actions by stating the Highway Code isn’t law!
Most of the time, the 3 car rule means that you end up angling your bus into traffic in an attempt to register in the dullard minds of other motorists that you are trying to get out, unfortunately everyone likes to play “beat the bus”.
2nd point - WRONG! The very subject we are discussing suggest that actually a reasonable and competent bus driver does have an expectation that traffic should give way to them, after all, it is written in the bible of safe driving that is quoted by courts across the land…the Highway Code.
I just love the IAM types…all full of righteous indignation that they are only purveyors of all things safe and good on the road. Why is it whenever i am stuck behind a Rover 75 on a Sunday doing 35 mph on a NSL single carriageway, they always seem to a ROSPA or IAM sticker in the car?
I’ll concede that the 3 car rule may not be polite or courteous, however it is never going to change until other motorists change their blinkered attitude towards public transport and realise that actually the 3 or 4 minutes you might lose travelling behind a bus is totally inconsequential in the grand scheme of things…whereas the poor bus driver has to explain why he is late, probably involving writing a report, put up with the whinging from the passengers because he is late etc etc.
And for the record, i believe the same priority should be given to HGV’s as well…after all, they have a job to do, which can have similar time constraints!
