Scanner:
FarnboroughBoy11:
eddie snax:
Scanner:
hitch:
I would lift and go if possible.
axles down in wind to improve stability
Is that from a DCPC module?
Not everyone one does stuff out of books, some use tried and tested experience
Some off that experience comes from when running 3+3 conssesions meant the axle had to be down, even on a light load
Why?
That does ring a bell from the dim and distant, when RFL for different combinations was completely crazy, thousands of pounds difference between a 6x2 and a 4x2 depending on what you plated them at, what kind of suspension etc etc. You also had to do mad things like change 5th wheel mounting bolts for weaker ones if you wanted to downplate from 38 to 28T for example.
That was at the start of my working life, I hope my claims are correct because my memory is awful!
Yeah thats right about the bolts, I remember an Owner driver who lived in our village brought an F7 ex Bartrums, it plated for 38 tonnes, he downrated it to 28 tonnes, mainly for cardboard
FarnboroughBoy11:
eddie snax:
Scanner:
hitch:
Why?
if your queiry is to do with the stability, then I cant tell you why, just that it does have an effect, if you have around 7-8ton payload or more on a 44 tonner, then when its moderatly windy, not put you on your side type wind, and not if its lashing down with rain so you’d aqua-plane, but dry or damp road, then with the mid-lift down you will find that the truck keeps a better straight line as the wind try’s pushing you around, whilst on a dual carriageway or motorway.
If your queiry is to do with the 3+3 thing, then on re reading it I’ll refrase it. when running on 3+3 consessions, anything that is not a fixed part of the trailer constitutes a load, and as such all wheels must be in contact with the ground, that included empty containers.
Hope that clarrifies it a bit
PS, I wouldnt run with a mid lift down except for weight, in any other circumstances, as some other have suggested, got to do your bit for tyres and fuel
