ROG:
Directly from the regs 561/2006 … eur-lex.europa.eu/LexUriServ/Lex … 013:EN:PDF
Article 15
Member States shall ensure that drivers of vehicles referred to
in Article 3(a) are governed by national rules which provide
adequate protection in terms of permitted driving times and
mandatory breaks and rest periods.===============================================
Article 15 shall be amended as follows:
– in paragraph 1, the following subparagraph shall be
added:
‘Where a driver card is damaged, malfunctions, or is
not in the possession of the driver, the driver shall:
(a) at the start of his journey, print out the details
of the vehicle the driver is driving, and shall
enter onto that printout:
etc etc etc
That will teach me to check the regs first before posting !!
hi ROG the Article 15 there have amended it from this one
COUNCIL REGULATION (EEC) No 3821/85 Article 15
Article 15
- Drivers shall not use dirty or damaged record sheets. The sheets shall be adequately protected on this account.
In case of damage to a sheet bearing recordings, drivers shall attach the damaged sheet to the spare sheet used to replace it.
- Drivers shall use the record sheets every day on which they are driving, starting from the moment they take over the vehicle. The record sheet shall not be withdrawn before the end of the daily working period unless its withdrawal is otherwise authorized. No record sheet may be used to cover a period longer than that for which it is intended. When, as a result of being away from the vehicle, a driver is unable to use the equipment fitted to the vehicle, the periods of time indicated in paragraph 3, second indent (b), (c) and (d) below shall be entered on the sheet, either manually, by automatic recording or other means, legibly and without dirtying the sheet.
Drivers shall amend the record sheets as necessary should there be more than one driver on board the vehicle, so that the information referred to in Chapter II (1) to (3) of Annex I is recorded on the record sheet of the driver who is actually driving.
- Drivers shall:
ensure that the time recorded on the sheet agrees with the official time in the country of registration of the vehicle,
operate the switch mechanisms enabling the following periods of time to be recorded separately and distinctly:
(a) under the sign : driving time;
(b) under the sign : all other periods of work;
(c) under the sign : other periods of availability, namely:
waiting time, i.e. the period during which drivers need remain at their posts only for the purpose of answering any calls to start or resume driving or to carry out other work,
time spent beside the driver while the vehicle is in motion,
time spent on a bunk while the vehicle is in motion;
(d) under the sign : breaks in work and daily rest periods.
Each Member State may permit all the periods referred to in paragraph 3, second indent (b) and (c) to be recorded under the sign on the record sheets used on vehicles registered in its territory.
Each crew member shall enter the following information on his record sheet:
(a) on beginning to use the sheet - his surname and first name;
(b) the date and place where use of the sheet begins and the date and place where such use ends;
(c) the registration number of each vehicle to which he is assigned, both at the start of the first journey recorded on the sheet and then, in the event of a change of vehicle, during use of the sheet;
(d) the odometer reading:
at the start of the first journey recorded on the sheet,
at the end of the last journey recorded on the sheet,
in the event of a change of vehicle during a working day (reading on the vehicle to which he was assigned and reading on the vehicle to which he is to be assigned);
(e) the time of any change of vehicle.
- The equipment shall be so designed that it is possible for an authorized inspecting officer, if necessary after opening the equipment, to read the recordings relating to the nine hours preceding the time of the check without permanently deforming, damaging or soiling the sheet.
The equipment shall, furthermore, be so designed that it is possible, without opening the case, to verify that recordings are being made.
- Whenever requested by an authorized inspecting officer to do so, the driver must be able to produce record sheets for the current week, and in any case for the last day of the previous week on which he drove.
and there amended that to be added in red
