wood73:
it was a tanker, in all honesty, it was 99.999% water with a few 5p size blobs on top.
Hi wood73,
Thanks for the extra info. ![]()
Iâm sorry to have to say this mate, but you were subject to full ADR, because you were given a UN number AND there are no applicable Special Provisions (SPs) available with UN 3082 (in the circumstances you described) to exempt you from the full requirements of ADR.
That is regardless of the quantity or ratio of water to other product, simply because the dangerous goods were carried in a tanker.
The stuff you were carrying (according to the consignor, but see below) was:
UN 3082 ENVIRONMENTALLY HAZARDOUS LIQUID, N.O.S., 9, PGIII
Having said the above, itâs possible that the consignor might have mis-identified the load.
I canât be absolutely definitive on this point without knowing a whole load of extra info, which is known only to the consignor.
The consignor classified your load as âdangerous goodsâ using UN 3082 as the correct UN number, so thatâs the info we have to use and therefore you were subject to full ADR on the basis that a tanker was used to carry the load.
You clarified (or at least attempted to clarify) that you were OK to carry that load, and you were very clear that you donât hold ADR.
Iâm sorry to say that (from the information given) it seems that your office probably got this question wrong, but you can comfort yourself with the fact that it was their responsibility to have answered your question correctly.
To my way of thinking, your office/TM had the opportunity to ask the companyâs DGSA to resolve the classification question with the consignor before you were sent/allocated to collect the load.
From the info youâve given, it seems that your office might have had difficulty with knowing the legal difference in ADR between âcarriage in packagesâ when contrasted with âcarriage in tanks.â
(You could have carried 1,000 ltrs of UN 3082 perfectly legally in packages without an ADR licence.)
Isnât it great that drivers arenât responsible for classifying whether a load actually counts as dangerous goods, or for deciding whether some/all of ADR applies to any particular job â â ![]()
