steptoe:
Hi Dave, or anybody else that might know.
Under ADR it says that tankers that are divided by partitions or surge plates into sections of more than 7500 litres must not be filled less than 80% or not more than 20% of their capacity, however do you know of any exemptions? Is there anything under ADR which allows a tanker that does not meet those regulations to be filled to a level between 20% and 80%? I am having a debate about this subject; I am being assured by a work friend that if a vehicle/tanker with sections greater than 7500liters reaches its legal road weight but is only 75% filled, then it is legal. This seems a load of old balls to me as it would rubbish the original regulation. I seem to remember not being able to load heavy products like caustic and acids in some tanks because there was not enough baffles and they would only be at 65% full when loaded.
Thanks
Hi steptoe,
This should help settle your work friend’s thoughts about “legal road weight.”
ADR 4.3.2.2.4
Shells intended for the carriage of substances in the liquid state or liquefied gases or
refrigerated liquefied gases, which are not divided by partitions or surge plates into sections
of not more than 7 500 litres capacity, shall be filled to not less than 80% or not more
than 20% of their capacity.
As your work friend will see, there’s no mention of “legal road weight,” so if he has a reference for what he says, I’d be very interested to see it please.
Sometimes, people have difficulty with the word “shell,” so here’s the definition:
“Shell” means the sheathing containing the substance (including the openings and their closures)
Another way to express the above is:
If a tank (or compartment of a tank) has no baffles and has a capacity of more than 7,500 litres, then the above applies.
So if you have the type of tank or compartment that’s greater than 7,500 and it has no baffles, then you can’t fill it to more than 20% unless you carry on filling it until it contains more than 80% of its capacity.
Equally, you can’t discharge that type of tank/compartment to less than 80% unless you carry on discharging it until you have no more than 20% of its capacity remaining before you set-off back on the road.
Obviously, this can present problems on multi-drop work, so some careful planning is required.
The above does not apply to tanks or compartments of 7,500 litres or less, nor does it apply to large single compartment tanks if they have baffles.
