tachograph:
delboytwo:
You all think its 15 minutes but its not its 30 minutes, the 15 minute is a option not a requirement.If you read the regs it says if you work 6 to 9 hours 30 minutes is required and if your boss requires you to have a 30 minute break then so be it.
The regulations require a break of at-least 15 minutes to be taken before going over 6 hours working time.
I don’t think anyone’s disputing that company policy can require a 30 minute break to be taken, company policy can require any amount of break, but that’s company policy not law, the legal minimum break taken before exceeding 6 hours working time is 15 minutes.
Wrong, there never say how long the break as to be before going over 6 hours,
If you read this and you will see why I say this
7.–(1) No mobile worker shall work for more than six hours without a break.
(2) Where a mobile worker’s working time exceeds six hours but does not exceed nine hours, the worker shall be entitled to a break lasting at least 30 minutes and interrupting that time.
(3) Where a mobile worker’s working time exceeds nine hours, the worker shall be entitled to a break lasting at least 45 minutes and interrupting that period.(4) Each break may be made up of separate periods of not less than 15 minutes each…
(5) An employer shall take all reasonable steps, in keeping with the need to protect the health and safety of the mobile worker, to ensure that the limits specified above are complied with in the case of each mobile worker employed by him.
there is nowhere in the quote that says 15 minutes is required, but there is an option to take 15 minutes
but there is a requirement to have 30 minutes between 6 to 9 hours or 45 minutes if more than 9 hours worked
the bit in blue say that it 30 minutes, and this is why employers (well some) ask you to take 30 minutes instead of 15 minutes in two parts.
lots of people think you have to have 15 minutes at or before 6 hours but you don’t is a choice, not required. The break as to be at least 15 minutes but does not have to be it can be 30 minutes if you so desired.
and here lies the confusion.
