Hi I’m going to drive class 1 lorry very soon as second job. Please check if I am ok with breaks.
Monday 7-19 lorry driver
Tuesday 15-22 warehouse worker
Wednesday off
Thursday 15-22 warehouse worker
Friday 7-19 lorry driver
Saturday 8-15 warehouse worker
Sunday 8-15 warehouse worker
Wednesday off
Saturday off
Sunday off
So I am not going to do more then 6 days of work so that is ok, at least 9 hours break between jobs so ok, every other week at least 45 hours break so ok, what worries me is reduced break on every Wednesday, is that ok or every other Wednesday I should have 45 hours break? Thank you
I’m reading this on my mobile but as far as I can tell it looks OK for both drivers/tachograph hours and WTD hours.
You won’t need to worry about compensation for the reduced weekly rest period on the first Wednesdays as it will be paid back with one of the long daily rest periods.
The reduced weekly rest period on the second Wednesday doesn’t need to be compensated for.
tachograph:
Thank you for your help, is it ok to keep records of my other work in diary and always keep it with me? As I think doing this as manual entry I am pretty sure I will make many mistakes, thank you
Krus777:
tachograph:
Legally you should keep the records of the work done on none driving days on charts or printouts but the DVSA will accept records kept in a notebook/diary, you only need to record the start and finish times of none driving shifts, it’s just so the DVSA can see that you’ve had the correct daily and weekly rest periods so there’s no need to record breaks.
In my humble opinion you should not under any circumstances try to manually put the none driving days records into a tachograph, apart from the time it will take and the risk of mistakes it will most likely play havoc with any analysis software if your company uses any, apart from that it’s just not necessary
By the way, I had a closer look at your times today and unless I’ve missed something it still looks OK
tachograph:
Krus777:
tachograph:
Thank you again for your help my friend, it’s amazing, really good points, one less problem to worry, have a great weekend
