Harry Monk:
Mike-C:
And i’m pretty certain (although not 100%) that six weekly inspections do not work out to a cost of £170-£190 a month. I’d love to hear from someone who knows first hand.
That’s about main dealer rate, it would be less from an independent.
It’s rare for nothing to need to be replaced at inspection though, at next week’s inspection I’ll also need a drive-axle brake re-line which will be about £220 + VAT and I’m sure there will be other bits and pieces which they will find which will push the bill up to £500, and that’s with a £20 per hour discount on labour costs.
I would consider myself very lucky if I ever got away with a £190 six-weekly inspection bill.
firstly, get it away from main dealer servicing/inspections
secondly, £220 for a drive axle brake reline
by my reconning, they are charging you approx £120 for the labour
i take it, your Magnum is on disc brakes all round?
you can do a pad change in less than an hour, so, they are stiffing you on the labour rates, or charging you fraudulent hours for the job
it is not unheard of for nothing needing doing on PMI inspection
as i posted earlier, when i first started out, i took my DAF to a main dealer on a service/inspection contract, the cost of that was £170 per month, which included 2 full services per year, 1 MoT and all the required PMI inspections
this did not include parts though, not even bulbs, but, it did include fluids
my first inspection cost me an absolute fortune in parts, as the truck needed a new cab tilt ram and a new load sensing valve
you can get it done by an independent garage or mobile mechanic for approx £60 for the unit and £50 for the trailer, the rates will vary depending on the area
