Wheel base measurements
When the wheel base is quoted on a three or four axle rigid, which axles are the measurements between?
For example, on a four axle, is it between the first and last axles, or axles 2 and 3?
Likewise, for a three axle, is it between the first and second or first and third?
Thanks.
The total wheelbase is the distance between the centres of the front and rear wheels, regardless of how many axles there may be in between.
Regards,
Nick
My assumption (and it is only that, I’m not claiming to be right…) is that on a 3 or 4 axle double drive rigid it would be from the 1st axle to the centreline of the two drive axles. If it was a 4 axle rigid where the 4th axle was a steer axle it would be from the 1st steer axle to the drive axle. Those measurements are what I would call the effective wheelbase as far as turning circle calculations are concerned, the convention for what wheelbase to quote might differ though.
Paul
repton:
Paul
^ this
for the purposes of calculating rear overhang on a 3 axle rigid it’s also from centre of the front axle to a point mid way between the two rear axles ( assuming it’s not a Chinese 6 :wink: )
for the purposes of specing a wheelbase for a new rear lift 6x2 rigid it’s the measurement from the center of the steer axle to the centre of the drive axle
Thanks guys.
