Hi. I am looking at buying a tractor unit but because my use is probably vastly different to the usual haulage, I’m looking for advice other than what a dealer might say…
I will have showman’s exemption as we do karting attractions at events, and will be towing an ex Halfords double deck Don Bur with fixed deck. The front end will be living accommodation, with sleeping pods on lower front, kitchen area and living area above inc bathroom. Top deck back will be garage area for the karts, as will lower rear, and mid lower will be workshop with doors opening to the side. There will be stairs to the top deck at the front, and all the heavy lifting is done by a tail lift. I suspect max load will be 5 tonnes.
Not that I will be in London much (if ever) but the Showman’s exemption I understand allows me to use in ULEZ areas no problem no matter what engine. It also means I don’t need an O licence.
Ideally I’d want a 4x2 unit, as I need to have a generator on the tractor unit, and as trips won’t be long, a single tank will suffice, allowing the genny to be located where the twin tank would normally be.
I’d want to use the bunks in the unit as extra crew accommodation. Ideally I’d like at least a 3rd seat in the cab - for extra crew too.
The big consideration is - that the annual mileage will be very low. Certainly no more than 3000 a year, probably about 2000. It will also be parked up from Sept - April. I know vehicles run better used regularly, so are there any trucks that don’t mind sitting around a bit?
I was thinking something like a late 2000s Scania R480 Topline 4x2, and have been warned off Renault Premiums / Magnums due to electric issues.
So… does anyone have any advice for me before I splash out my hard earnt and make a ghastly mistake?
Thanks in advance
