tachograph:
Brake pad/shoe wear warning lights are designed to come on long before the brake wear becomes dangerous, it’s simply a light that tells you that you should do a visual check of the pads/shoes.
Obviously you was right to inform your transport office and they should make arrangements for the brakes to be checked, but when the light first comes on brake wear should not be an immediate problem and I very much doubt that the DVSA would see it as such.
If the brakes are not effective as you say then that’s an entirely different matter and the vehicle should be checked immediately, to simply say “leave bigger braking distance” is completely unacceptable.
The fact that both vehicles have the same problem and one vehicle has a slow puncture suggests that your company have a very cavalier attitude towards their vehicles, personally I wouldn’t want to work for a company that had that sort of attitude.
Part of the reason their attitude is like this is because it’s a small operation, 2 vans 1 full time driver 3 brewers 2 sales and that’s it, small business attitude, I’m not saying its the right attitude hence posting my whinge in here but I’m glad I’m not the only one that thinks it’s unacceptable, thank you for your advice!
I now feel like ■■■■ for telling the head brewer I was driving a defective vehicle
dieseldog999:
its a sprinter.brand new sprinters have no brakes…most sprinters have no brakes…mercedes used to have to write to test stations explaining that the pish poor reading on the rollers were factory standards…sprinters have never ever had decent brakes…stop being a complete fanny…unless your tyre is well soft,then it wont matter anyway to vosa…so why worry…if it bothers you so much,let it down flat when your in the services,and rally it around till it rips off the rim,problem solved…
It’s a white sprinter too, has no indicators mirrors headlights and the accelerator is stuck open
I was laughing along to your post til I read your location and realised you were probably being serious
I’ll pass on the Irish advice though!
