using poa
hi can u settle an argument by using POA does extend your 6 hours rule by the time u are on Poa
Clarki666:
Yes POA pauses the Working Time clock (but doesn’t reset it as a 15 minute Break would). So if you work/drive for four hours, then go on POA for an hour, you still have another 2 hours work time before a Break is needed.
Sent from my VOG-L09 using Tapatalk
Clarki666:
Yes and so does break
Many find using poa messes up the driving time on the tacho because the softwear assumes wrongly that poa is break
Thank you i no it doesn’t count towards a break our new transport manager is saying it doesn’t extend the 6 hour working rule but was always told even when doin a cpc
course by using POA it does extend it as long as you have a break when you have actually worked for 6 hours
