newmercman:
Carryfast, a second to none workforce, don’t make me laugh, it is well documented that BL quality control was appalling, who do think it was that put the stuff together?
The Mini, the best selling vehicle they made and each one at a loss, what a superb strategy that was by the management, to compound that they threw it together in the usual shoddy manner so it would have lots of warranty claims too, talk about management and shop floor working in harmony, they nailed it on this one.
Now let’s talk about your long stroke obsession and something anorak has asked you numerous times, force on the rods and big and little ends. Get two pieces of spaghetti, snap one in half and leave one alone, which is stronger in a tensile load situation?
Obviously the shorter one, so therefore a shorter stroke requires less metal, which means less weight, it also makes it a lower profile, both important parameters for an engine of that era.
Not everyone wanted to be first up the hill, not everyone wanted to drift around roundabouts, not everyone wanted independent rear suspension, limited slip diffs and 4.0l V8s. BL was building cars and lorries for the masses, the vast majority of which wouldn’t know a single thing beyond turning the key, putting it in gear and pulling away to start the journey to wherever, that was the criteria they had to satisfy, yes they made a complete balls up of that with a combination of dreadful management and poor workmanship, but the mechanicals were up to the job.
Front wheel drive a mistake? Really? Are you on crack? Is every car manufacturer in the world with the exception of BMW wrong? Seriously mate that one statement is the most ridiculous one you have ever made and there’s quite a few to choose from…
It was the same workforce that put the Westminster and Cambridge and A40 together.No problems there at all.Repeat custom no need for discounting.
RWD Mercedes not just BMW got that wrong then.
The truth It’s just a way of saving production time engine, transmission, final drive all stuffed in from underneath in one operation so more perceived profit.
Remind me what happened to GM and Ford after introduction of Taurus and Mondeo and Vectra.
It was all downhill from that point.
The driving quality at the wheel is far better with right wheel drive no need for any Roger Clark and Tony Pond rally driving antics.Although power induced neutral to oversteer is a bonus over power understeer.
I thought we’d already sorted that the con rod and ends aren’t in tension during the power stroke they are under a compressive load.It’s the head fastenings and main bearing cap fastenings which are under tension.
Which is all the the only thing that’s providing the torque required to move the truck and the piston needs to put enough shove into the crankshaft only every other revolution of the engine to do it.Best to have as much leverage at the crankshaft as possible to help with that.
I’m sure that a stick of spaghetti doesn’t have limitless strength in compression at any length let alone if you put hinge points at each end of it.
So how do you intend to compensate for the RR’s 7% leverage advantage with the TL12’s less than 5% piston area advantage added to the increased load on the con rod assembly.
That means 7% more load on the con rod assembly and 2% more cylinder pressure to get the equivalent torque output at equivalent rpm.
Let alone if your opponent decides to go for the same 12.4 litre capacity using the same bore stroke ratio as before.
Oh and 7% and 2% of a lot is a lot.
As for the cylinder head joint, unlike a gun barrel and its breech, having no facility to allow compliance for recoil loads is also a game changer regarding cylinder pressures used to compensate for having less leverage.For every action there is an equal reaction with no way of allowing the the engine to move back with it, unlike a gun.The gasket and the head fastenings have to take the full force of the punches not roll with em.
So when do we get to try this TL12 at 320 hp at 1,950 rpm.If it survives that we’ll turn up the boost to the full fat 1,200 lbft at 1,200 rpm and 400 hp at 1,950.
Hopefully the dyno shed is well insured.
