http://www.trucknetuk.com/phpBB/posting.php?mode=quote&f=35&p=2703005
As I said I can’t give you an answer because I don’t get the premise on which your question is based.
Which if I’ve got it right is that the inertial/kinetic ? tensile load of the piston and rod assembly at TDC, between the compression stroke and power stroke, or exhaust stroke and induction stroke, equals, if not exceeds, that of the compressive load on the assembly during the power stroke ?.
Or that the mechanical/leverage advantage provided by a longer stroke in that regard and resulting specific torque output, is cancelled out by supposed piston speed issues and their result on the supposed tensile loads ?.
jstor.org/stable/44579567?se … b_contents
When as I’ve said the design of Rolls Eagle, Mack 673 , to ■■■■■■■ ISX to Paccar MX etc all prove the case for maximising the stroke dimension.
Also the fact that AEC engine designs were compromised on that basis.
Please produce your “fact” to support your outrageous suggestion.
AEC during the 67 years of its existence produced and sold close on 750,000 engines. These were used in its own vehicles and in many other makes of commercial vehicles at home and overseas. In addition to road going commercial vehicles it supplied diesel engines to just about every application that used diesel engines: - pumps, generators, marine main propulsion and auxiliary units, rail traction, excavators, mobile cranes, static cranes to name some of them. If the AEC engines were compromised because of design failings then this major British company that exported world-wide would never have achieved the success that it did.
I will give you a fact. It is this. You do not have a clue about AEC, the company, the products, the people and personalities that managed it and worked there. So before you write another incorrect statement about AEC, I suggest that you do some proper research, and I will gladly point you in the direction of the vast archives about this great company that exist.
Try the National Archive at Kew, not too far from your home at Leatherhead. Here you will find minutes of monthly board meetings for every month of the company’s existence, both as an independent entity and also as part of British Leyland. Board meeting minutes detail monthly warranty claims and payments, so maybe you might find evidence of the occasional engine failure… it did happen as happens in every engine manufacturing company.
And try the British Commercial Vehicles Museum at Leyland. There you will find build sheets for virtually every AEC PSV and lorry built. You will also find service bulletins issued by Southall to its regional depots and service engineers. These documents give details of problems occurring in service and the remedies for them. Strangely enough, problems still occur with new trucks today. I have had three '69 plate DAFs notified for recall in the last week.
And if you still haven’t found the fact to support your supposition that every AEC engine design was flawed, then try the Motor Industry archives at the University of Warwick. Many leading automotive industry experts and senior managers, including Bob Fryars, have placed their own personal memoirs and papers in the care of this archive.
Instead of googling dubious information on the internet get out there and conduct your research in “hard copy” archives. You will find it fascinating, but when you are doing your research be prepared to allocate a lot more time to it than you think it will take. Because in these archives, whilst you will go with an intention to research a specific topic, you will find that some other gem of information catches your attention and it will take you into another area of investigation.
So, good luck with your research, and when you have learned about AEC, feel qualified to state you opinions about the company, its vehicles, and its engines.
