I’ve finally taken the plunge and applied for my C provisional and when it eventually arrives hopefully will have saved up enough to start training.
Pretty much noone seems to have manual training vehicles anymore and while I think taking the test in an automatic would be advantageous it would have been good to have as part of the training some time with a manual box.
It seems that the most common manual trucks in operation are either 4 over 4 or slap over configuration. Would I be right in my assumption that these are synchromesh boxes and that crash boxes are really only seen in the uk in much older trucks or heavy haulage etc?
jonathan_dyane:
There are so many different types of gearbox and you get to train in just one of them
What happens afterwards is that you ask another how a particular gearbox works when you come across an unfamiliar one
If you can drive a manual car you can use a splitter or range change without problem, you are just repeating it more often, a month down the line you will laugh at this post
jonathan_dyane:
Doubtful you’ll find a crash box in anything dated within the past 20 years over here. Most 18 tonner manuals are just a straight 6 config box similar to your car. It’s only when you start getting up the weight range do you get the 4 over 4s either slap across or with a range change. You don’t tend to find splits on rigids unless it’s an artic-spec cab. But 90% of trucks are auto these days anyway.
Cheers guys, I’m probably overthinking!
