Stralis Computer Reset HELP!
Number of warning lights i.e., RFC, bulb failure, ABS blah blah etc flashing on our 2015 - does anyone know how to reset these warning lights without calling dealer/laptop person? Will a battery disconneciton reset work and is it just a case of disconnecting battery for 5 minutes or is there something else to it?
Try switching all the electrics off, then holding the battery switch in until it clicks, usually 10-30 secs, that should reset all the electricals. Works on the ones I have been driving until recently.
redford9000:
Try disconnecting the battery terminals and touching +ve to -ve to do a hard battery reset. You might find it’s low battery voltage and they’re on the way out and the problem. Next stop would be checking fuses then wiring harnesses with that many faults.
You may have got bulbs and ABS problems though in the first place. There’s two bulbs arranged vertically in the rear tail light cluster and it does detect one going which often catches a lot of people out.
