What I’m saying is that the ‘combination’ of factors such as heat and compression pressures in a diesel engine,which are designed to ignite and burn a charge of diesel fuel,can (probably would) detonate a charge made up of high octane fuel designed to be ignited and burnt in a spark ignition engine which has a totally different set of factors designed for use of that type of fuel.You’re not going to believe me so just ask any diesel engine/truck manufacturer if the engine’s warranty would be upheld if you decide to run the thing on LPG instead of Diesel.Simples.
Hi Carryfast,
Whereabouts were we discussing truck manufacturer’s warranties?
I’m trying to stick to basics for a very good reason, so please humour me for a while. ![]()
I asked you a very straightforward question:
dieseldave:
Are you saying that the normal running temperature achieved by a normal diesel engine would be hot enough to ignite/detonate a petrol/air mixture by compression igniton alone?
Of course, you’d need to bear in mind the automatic ignition temperature for petrol when you answer.
BJD has asked you pretty much the same question:
Big Jon’s dad:
Carryfast have you now accepted that simply replacing diesel fuel with petrol, in an otherwise unchanged diesel engine, will not result in the petrol/air mix igniting before the diesel/air mix would have done. Yes or no will be fine, we can take it further if need be, but your answer will show if you have understood anything we have been saying.
I’d say that yes or no would be fine, but please feel free to add an explanation that’s to the point you’re making if you wish.
It looks to me (and I’m always prepared to be wrong) that you’re theorising advanced stuff seemingly without you first having a grasp of the basics.
I think that’s the issue with your posts on this subject in a nutshell.
I’m not knocking your ability at explanation, but you do seem to be shifting uneasily from one idea to another.
Just above, you wrote “can (probably would)” which doesn’t quite seem the same as what you wrote previously:
We don’t put spark plugs in diesel engines because they detonate diesel fuel using compression ignition under massive cylinder pressures and temperatures which would ignite petrol long before the spark does on a petrol engine.
In the second quote, you seem quite certain because you wrote “would.” Some proof of “would ignite petrol” would be good please.
You also seemed quite confident and definite when you wrote this:
There’s no way that petrol can withstand the cylinder pressures and temperatures generated in a diesel engine without detonating unlike diesel fuel.Simples.
If it’s so “simples,” could there be some proof one way or the other please??
It might just be me, but I’ll own up that I’m really struggling to understand just what you’re saying, and I believe that it’s a lack of anything independent and verifiable in support of your contentions regarding the basics that’s preventing me from doing so.
