My work seems to think it’s correct for me to stand in between a tractor unit and a trailer to perform an operation. Driver NOT in cab.
I belive this to be wrong and iv brought this up with management several times.
Can I get your thoughts please as I’m ready to take this to the HSE.
Thanks for your time in advance.
Panzerlancer:
What is the “operation” you are “performing” ? Your post is vague and light on detail. Unless you say specifically what it is they are asking you to do and why you believe it to be wrong then no-one can help you.
How else do you connect the air lines and power leads?
And check the bar sitting across the kingpin
