Hi,
Just wading through all the set up etc and wondered about the supplied CAR ADAPTOR;
was told it can plug in to BOTH the car and truck cigarette ports to power it. Dont need a voltage dropper ! is this correct?
does say input DC 10V -36V and output DC 9.0V
Anybody got one of these and can shed some light, be great thanks
Scenic:
Hi,
As it say input 9v to 36 v means you can plug it into a 24 volt system so you don’t need anything else.
Mainly things like Laptop chargers and inverters that are voltage specific due to them upping the voltage from say 12v to 19v for lappy or 12v to 230v for an inverter.
My laptop charger will only run on 12v, my inverter will only run on 24v, my kettle will only run on 24v, everything else will run on either.
