Scania coupling light?
Anyone know how to turn the scania coupling light on? Looked everywhere with no joy and first time in one?
If there is a light on the back of the cab there will be a switch. I use a Scania but without being in the cab I can’t recall where it is. It is an additional fitment so quite likely to vary from unit to unit.
This is what I use. My old Petzl head torch mounted on a safety hat. Trouble with a head torch is the elastic goes within 2-3 months. Whilst I was doing recovery work (when a head torch is essential) I was delighted to find the torch in the bottom of chest of drawers I hadn’t looked in for years. I chopped out the harness and mounted the torch with small 4mm bolts. Fits lower down than a normal safety helmet so it doesn’t blow off in the wind at ports where I go quite often these days.
The one bit of kit I wouldn’t be without - with the added benefit of rain protection. The helmet is a Portwest full brim which are available on ebay for about £7. Presumably as helmet is now modified it is not to regs but no one has asked me to take it off.
Top right, above the rear fog
Sent from my SM-A520F using Tapatalk
On the newer models it’s top right on the door itself near mirror adjust buttons
