Hi 1970commer, I saw these earlier today but decided not to post them at the time, but in the light of your post they may help.
I was interested to learn more about this type of engine because, until its come up in this topic, I wasnāt aware of it. If you have an open mind, you can learn something new every day.
Driveroneuk:
Great video that Driveroneuk, obviously now you have posted that Bking will be telling us all that the only way you can get one of these engines to run backwards is to turn the belts over that drive it, seriously though I have seen cutaway engines like that before but never a TS3, they do make a lot more noise than that in service though, especially when passing Dan Punchardās Dennis Pax, which is quite a regular occurrence.
Tipper Tom:
Can you run a diesel on vegetable oil? Itās so similar itās not worth arguing over
Iāve done it with second hand stuff ,it stinks ,you canāt get started very well ,and you need to keep plenty of filters with you ,It sticks to everything ,and takes ages to run through to get rid ,( cheap motoring though) !
Iāve had a thing for the TS3 since I could hear one running outside the classroom window at college - the HNC boys rebuilt it every year.
Love the Junkers Jumo animation - thanks! Coincidentally, I found myself working on the Leyland L60 at REME in Long Eaton in the 70s; this also was a 6-cyl vertically-opposed-piston multi-fuel engine (I believe a copy of the RR K60) fitted in Chieftain tanks - the Shah of Iran had sent all his back because they were too smoky!
Tipper Tom:
Iāve done it with second hand stuff ,it stinks ,you canāt get started very well ,and you need to keep plenty of filters with you ,It sticks to everything ,and takes ages to run through to get rid ,( cheap motoring though) ![/quote
I was trying to illustrate that if the engine will run on vegetable oil. Thereās no reason it wonāt run on engine oil.
I know a few guys who ran their off road (not road legal) 4x4ās on engine oil and others even used old hydrolic oil, they never expected the cars to last long anyway
The diesel engine was originally designed and ran on peanut oil
Believe this was deigned to run on anything available in the field - kerosene, avgas, cooking oil, ā ā ā ā ā ā ā , anything!
Another memory just surfaced - in the tanker driversā strike in the 70s, I was working at a garage serving fuel (you had to go out, put the fuel in, take the money, get the change, etc, in them days). The local 8-legger man came in but we had run out of derv. The boss said, āYou get as much paraffin into him as you can, Iāll get some 2-stroke oil!ā Off the tipper went leaving a trail of stink-wheel smoke
Drift:
A mate of mine done it with a Terrano piece of crap using practically neat veg oil, at one point he was buying the used stuff from the local chippy. I told him it would eventually knacker the injector pump but he wouldnāt listen. āāāheard it on the internet its okāāā etc etc.
The veg oil turned the rubber diaphragm inside the pump to moosh leading to the effect of jamming the throttle wide open and it blew the motor.
Seeing as thereās abit of an engine lesson going on, hereās a good animation of the apposed piston Napier Deltic engine-
With its ports at the end of each cylinder.
Once built for mine sweepers and landing craft in WW2, they were later adapted for rail use.
Very powerful for their size, each Deltic locomotive has 2 rated at 1650 HP each for a total of 3300HP.
They were rated at nearer 3000HP each in marine use.
Several lads at the quarry ran their Fodenās on a % of old chip oil with no problems as long as the fuel pipes were lagged with hot water hose from the radiator. Transits and LDV vans will accept it OK as long as a Bosch pump is fitted, Lucas/CAV are not so tolerant. The guy who does my MOTās runs his Japanese 4X4 on filtered hydraulic oil and has had no problems.
Gembo:
Seeing as thereās abit of an engine lesson going on, hereās a good animation of the apposed piston Napier Deltic engine- http://www.youtube.com/watch?v=D3bj47TAYiU
This threads great !! And bking ⦠Your wrong just admit it
Correct me where Iām wrong wasnāt military equipment designed to be multi fueled?? The theory being it would run on just about anything from paraffin to heating oil
Used to run my old bn2 vw passat 1600 on a 75%tescos pure veg oil and diesel mix , it used to run better than regular diesel although it used to smell like a mobile deep fat frier , unfortunately they bumped the price up and I wouldnāt risk running modern pump on it let alone a common rail setup
windrush:
Pete.
After buying a mint little Peugeot 205 turbo off fleabay to run about in, was gutted to find it has a Lucas pump Oh well, Iāll just have to put up with it only doing 50 - 60 mpg on white.
Gembo:
