Red warning light
If you have the red warning light on and brake wear symbol for one of the rear axles ,yet nothing could be found wrong ,can you still drive the vehicle :question:
I would say so but keep a copy of the mechanics report with you .
I’ll stand to be corrected…but i’m pretty sure you cannot drive with a red warning light. I.e it would be a test fail and would also leave the vehicle with a stop notice if checked. If the red warning light is not correct, i.e there is nothing wrong then the garage.fitter or whatever should disable it. And record what they’ve done.
