Hi All, As the title suggests, I need some info on how to reset the time on a cd type tacho in a DAF XF asap.
Cheers in advance.
Cheers in advance.
You have to remove BOTH tacho’s, turn the ignition off and on again, then IIRC it’ll allow you to change it…
HTH’s…
Luv
Chrisie… ![]()
Which button do you press and do you have the draw open or closed? Sorry for the questions, but it’s not for me and I won’t be there to fiddle with it (it has been a while since I last reset a tacho and it has gone clean out of my mind!!)
Door shut, and i think it’s the M menu button, then + & -, or just the later…
smcaul:
I thought it set itself to the correct time? at clock forward or back you make sure the discs are out close the drawer turn the ignition off and next time you turn it on it adjusts auto…
Not sure how or if you can adjust it manuallyâ– â– ?
Thanks, Will pass the info on, hopefully with a bit of fiddling and using the above it will all work out.
