Ok let’s see where this one goes. latest driver buzz coming out of a big company:
If you do a printout for whatever reason do you need to keep the printout for 28 days? (because this then becomes a legal document)…even if you were just checking your driving hours etc.
WTD…you start work at 0600 have a 15 min break at 0900…for wtd can you then work another six hours or just until 1215…(this assmes that you haven’t driven for 4.5 hours)
like I said this is coming from a big outfit and the drivers have all got different ideas, confused dot com YES
cury:
No you don’t necessarily need to keep it, a printout only needs to be kept if it’s taken for the purpose of writing manual entries on it.
But why do a printout to check your driving hours when it can just as easily be seen on the display.
cury:
WTD…you start work at 0600 have a 15 min break at 0900…for wtd can you then work another six hours or just until 1215…(this assumes that you haven’t driven for 4.5 hours)
If you have a 15 minute break at 09:00 finishing at 09:15 you can continue to working until 15:15 before needing another break for the 6 hour rule (6 hours working time from the end of the last break).
cury:
A required printout must be treated the same way a tacho chart is, kept for the required period, handed in, kept for the required period. A printout for any other needless reason such as checking hours or you wonder what happens if you press this button has less use than toilet paper and can be binned.
cury:
cury:
cury:
