POA and breaks
Sorry for th dumb question, but what does POA stand for?
Riho:
Period Of Availability
Just need some guidance about how or if POA affects what breaks need to be taken.
Example1: If i work 5 hours then have POA of 30 mins do i have to take a break after another 30 mins to comply with WTD? So what i am really saying is can POA take place of break or can it delay when you take a break , eg If I work 5 hours , take 30 mins POA , can I work another 1 hour before taking a 30 min break.
Example 2: If i drive for 4hours then have 1hour POA the driving time is wiped clean on the digi tacho. Does this mean I dont need to take a break after 4.5hrs driving?
Different people I have asked have given me different answers so there is obviously confusion out there!
As I understand it using POA doesn’t take place of u’re break, if u use POA u musnt be doing any other work it’s there for known periods of delay or waiting. If u do 1 hour POA after 5 hours work then u still have 1 hour before u have to take u’re working time break. Hope this helps.
POA is not break
Break is break, rest is rest.
Take 15 minutes break here.
You have to take a break at 4.5 hours driving, in this case you haven’t had a break.
Remember the Hobbs mantra, if it qualifies for POA, it also qualifies for break, so take a break if it doesn’t affect your wages instead
goodygus:
You need a break of at least 15 minutes after 6 hours work (driving and other work). POA does not count as work so you would not require your break until completing another 1 hour work in the situation when you have 30 minutes POA after 5 hours…
goodygus:
No, you must take a break of at least 45 minutes at 4.5 hours in that situation. Under normal operation POA is not break even though the digi tacho incorrectly regards it as such.
Cheers coffeeholic that is exactly what I wanted to know. Hopefully no more infringements!
