5thwheel:
JCD car transporter, anyone know what JCD stands for ■■?
Perhaps “Jack’s Car Deliveries” Dean,lol,lol!
David
[/quote]
Have they let you out the home again David ? Will have to have a word with the matron and have
the medication increased chap !!
Buzzer:
Those Mammoth Minors turned out to be a disaster IIRC. I recall Bradys had 6 on order in 1967 to take advantage of the new '68 Transport act to run at 32 ton gvw but the lone Mandator they ran gave so much trouble they cancelled the order and bought six 6x2 Atki rear steers G reg from memory. Cheers Dennis.
Dennis I was the proud owner of a AEC Mammoth Minor as it was called on a J reg but on round timber it was a nightmare, like a bloody see saw so the second steer axle I had removed and had a long wheel based Mandator but with AV760 she could fly and was more comfortable because of the longer wheelbase.
Any pics Buzzer ?
gingerfold:
The early Ergo Mandators with the AV691 engines were the troublesome ones, overheating being the usual problem caused by a combination of thick cylinder liners, small radiator, and poor air flow around the engine because of constraints caused by the cab. The AV760 with thinner cylinder liners which dissipated the heat faster was a different proposition all together and a much more reliable engine. The twin-pass radiator as it was called, also improved cooling. By early 1967 the AV691 option had been quietly discontinued for lorries although it was still used in horizontal format for the AEC Reliance coach, which could carry a much bigger radiator. The last Mammoth Minors were made as late as 1971 for Air Products. There was no need for that axle configuration by then for 32 tons, but Air Products had designed some trailers specifically for going behind a Mammoth Minor, and rather than alter the pin position on an expensive pressure tank they asked AEC to build some Mammoth Minors for them, unbeknown to the top brass at Leyland, who weren’t at all happy. As for the twin-pass radiator, when I had my restored Mandator it put the fan into the rad one day when I was running unit only over a very rough road surface (the fan on a AV760 engine ran very close to the rad) and when I had the rad rebuilt it was done, wrongly, as a single pass system and afterwards even running light there was a noticeable increase on the temp. gauge when climbing a hill. Previously with the correct rad. the temp. gauge never moved.
Thanks for the comments “gingerfold” ,you have a lot of valuable knowledge that you contribute, thanks.
moomooland:
10A colour shot of of a H. Baker AEC Mandator loading up in Bradford.
Thanks for the photo Paul,nice !
Punchy Dan:
Looks like there’s a Foden behind John wards 88 pushing him on a straight bar
Other way round “Punchy Dan” the 88 is pulling the Foden as well ! They were always getting in the way
them Fodens !!!
ramone:
The H.Bakers Mammoth Minor gave problems , apparently it threw flames from the exhaust according to one of their drivers who is sadly no longer with us. It went back to Tillotsons in Bradford but they couldn`t cure it. The 4 x 2 Mandator loading bales was eventually sold to B.Holmes waste paper in Bradford and my dad drove it . By this time it was 10 years old and past its best , it was a regular over the M62 running at full weight to Ramsbottom
Thanks Ramone for the comments !!
