1931 and Somerset milk heading for London.
Oily
Buzzer:
essexpete:
Is the od looking “cabover” or forward control a pre war Ford?Its an 1936 Studebaker, Buzzer
I never knew Studebaker built commercials.
Buzzer:
Buzzer
Cant disagree Buzzer certainly bogged I can only surmise he tried to cross a flooded crossing, the eastern states have had their fair share of rain and flooded roads and rivers this year.
Dig
Les Sylphides:
All these are Fordsons:
Lot of similarity between the Wartime Fords and the 50s and 60s Knocker Commers
Dig
essexpete:
Buzzer:
essexpete:
Yes they did, the Dinky Toys tankers from the 1950’s were based on a Studebaker.
Pete.
DIG:
Buzzer:
BuzzerCant disagree Buzzer certainly bogged I can only surmise he tried to cross a flooded crossing, the eastern states have had their fair share of rain and flooded roads and rivers this year.
Dig
Yes, I think you are right Dig, it certainly doesn’t look as if he came off a bridge, but, before my time in NT, I was told of 2 trains which collided head on on one of those long curved single tracked bridges with one ending in the oggin.
Doesn’t look as if he was loaded either, no obvious exit damage to the crates and no signs of survivors inside. Perhaps if he had been, and had been hit by a wave, the extra weight might have been a help. Of course if the road was washed out beneath the surface, I have experienced that in Qld. and NSW, he’d have been over anyway.
windrush:
essexpete:
Buzzer:
essexpete:
Pete.
They were big players in light truck market of 30’s and 40’s.Known for the WW2 US6 6x6 and 6x4 which was similar to the GMC type.
Also tractor units.
It started out as a well respected horse drawn carriage maker.Then progressed through the early horseless carriage years like REO, they can both be seen in the London to Brighton veteran car run.
Thanks to robthedog, Les Sylphides, Buzzer, DIG and windrush for the photos
Oily
Scania variety credit to Peter Schöler for the photos.
That first Scania, wagon and drag, very posh, some might say wastefully so in view of its likely cargo, very heavy and possibly very mucky.
Spardo:
Aye. Low side skirts on a tipper? Is it on factory only work?
Franglais:
Spardo:
That first Scania, wagon and drag, very posh, some might say wastefully so in view of its likely cargo, very heavy and possibly very mucky.Aye. Low side skirts on a tipper? Is it on factory only work?
Or just for shows, never actually working…
Now, that old F88 of Ewan Booth. Can he not be arsed to clean his passenger window, or has he lost his own to a stone shower?
Buzzer:
Buzzer
d
Don’t know the knob personally Buzzer but I believe that is a second generation 13 speed RR one you can split each low range gear but not really sure.
Dig
DIG:
Buzzer:
Buzzerd
Don’t know the knob personally Buzzer but I believe that is a second generation 13 speed RR one you can split each low range gear but not really sure.Dig
Dipster:
Franglais:
Spardo:
I recon they are side tipers there not usually high but I think longer than normal for for and aft tippers.
These are the real heavy duty units a bit higher and longer these trucks are grossing 170 tons on this job.
Dig
Star down under.:
https://youtu.be/f-R68_Jd3Fw
That is some heavy kit.
