Retired Old ■■■■:
Get yerself technologized!
Did you do that corn circle image of that ERF R.O.F. It’s very good,did you do it after “chucking out” time or before ? After I would think as you would have been “clocked” early on ! Anon 1.
Not one of mine, Dennis, I only do Guys with that “proper” badge on the front!
Lawrence Dunbar:
leylandlover:
Anyone interested in a light 6 Foden? 180 Gardner 12 speed box alloy bodied tipper.Its located in Sedgley West Midlands.Owners want £2500,also lots of other spares Rockwell axles ex 8 wheeler Foden 2 Fuller 13 speed gearboxes Edbro 20 ton ram.Pm me for photo of Foden because I dont know how to upload it
Where’s Larry Dunbar, he’s a Foden man.
Never fear Larry is here Dave, Its sounds good, But Im only wanting a tractor unit an S36 etc, Less bolas to worry about, Regards Larry. PS This sort of Foden.
I will keep my ear to the ground Larry.
we are talking proper lorries now , proper gearbox , 6 speeds were for wimps . that one of larries was always my favourite marque , comfy driving position with all the controls to hand and they went well for their time with all those gears to play with . i think they were too technical for the more southerly amongst us . dave
Well Larry you could shorten it,sell the alloy body to help cover costs.It is the same cab as your old unit.It was parked up to be replaced with an 8 wheeler.
I’m going to try putting a pic on here for young leylandlover. Don’t know if it will work, though!
There ya go. Is that the one, Clive?
Those Lightweight chassis were mainly aimed at the mixer market, Tilcon had loads of them. Fodens fitted the ‘old’ S39 cab instead of the then current S83 cab to (a) reduce weight and (b) they were less prone to damage on sites and were easier to repair if they did get knocked, plus there was no fancy cab trimmings to get dirty. They fitted the later eight/nine/twelve speed (take your pick!) gearbox with the auxillary shift on the main gear lever, hypoid rear axles and used Stopmaster brakes, again to save weight, but they were not the finest braking system in the World!
Some had Super Singles fitted on the rear as well.
Pete.
You’re most welcome, my boy!
rigsby:
Mention of those POXY Stopmaster brakes has just rounded off a thoroughly bad day, still waiting for a dust shroud for an ABS sensor so I can’t put the trailer’s hub and disc back on. I am used to having problems finding pars for 50/60 year old vehicles, but BPW axles FFS there are thousands and thousands of them in use, so why is everything nil stock? And on top of that I could murder whoever at Utility (York) trailers decided to penny pinch with the wiring for the top marker lights - so short I can’t even get behind the lamp to cut the wiring which is in box section; I shall be attacking the thing with a disc cutter to get at it I think.
Ugh, trying to get past the walking beam and elephant’s feet on a Foden to persuade seized Stopmaster adjusters to start moving, invariably to find that the backplate slot was completely mullered.
leylandlover:
Hi Leylandlover, My Foden was a S36 Single piece windscreen, This one is an S39, Plus it will not be tax exempt being a R reg.Anyway Im retired as you know & haven’t got the gear that I used to have, But having said that I still have a little bit, Plus all the knowledge on how to get a old Foden going, Regards Larry.
Retired Old ■■■■:
Well ROF, Looking at the picture It looks quite tidy, I would probabley make a good 6 wheel tractor unit it looks to be a very short wheel base, Regards Larry.
Retired Old ■■■■:
This Stoke on Trent Reg Foden ■■?, I didn’t think that Fodens were still making S39s in 1976/7, The S 80s were in production in 1972, , Any info on this query, Regards Larry.
Lawrence Dunbar:
Retired Old ■■■■:
Read my last post Larry!
The Lightweight range were introduced in 1976.
Pete.
There’s a showman type,same cab and power on ebay at £14000
windrush:
Lawrence Dunbar:
Retired Old ■■■■:
Pete.
Thanks Pete, I do remember Tilcon at Gateshead having them with the Super Singles on, Regards Larry.
Another pic of it – it’s been in that spot for a long time!
Indeed it has 1989
How do I know? I was in their yard last Saturday and I used to work with them.
Well if you are going to roll your eyes at me , I’ll happily delete my picture if you have taken offence for some reason-
Sorry I hit the wrong smiley.No offence meant
