peirre:
so long as you don`t accidentally put the forks through the curtain on the blind side. As some genius did to my trailer with a telehandler a while back
The one on the truck wonât reach that far. To bring the pallet across, you get as far under it as you can (just over half way) lower the legs, and slide it back towards you till you can get fully under it and lift. The only time you risk damaging your curtains is if you accidentally push an empty pallet across the bed at an angle.
As stated it does make unloading a lot quicker and easier, especially if youâre in a tight yard or pulled across a driveway.
Oh, and one other thing weâve learned from experience. Hose the Moffett down regularly, the crap really builds up badly if you donât and can get under the panels where the valves and relays are, causing them to stick or fail.
Constantine:
One question, how do you make sure the side lights are well protected as surely they are put on by the manufacturer and we canât tamper with them very much as they are for C+U reasons?
Specify flush-fitting ones. Ours werenât originally, and it only takes a brush against a hedge to break the lens cover off. I think the latest ones should have been upgraded by now.
Hey Sidevalve,
Thanks for clarifying the side markers, if I manage to get into the Moffett side Iâll most probably being using older ones if I am inexperienced, so its worth bearing in mind the casing can get easily damaged, understandably, but best to try and prevent it first
C
