Mercedes Actros MP4 ran out of fuel ** HELP
Hi Guys,
My actros Mp4 ran out of fuel, now it’s cranking but not starting, what I’ve done so far.
  1. Put 100 litres of fuel
  2. Using the hand primer pump on the fuel filter housing (on the left side of the engine) - it seems like its not pulling fuel up there’s no resistance at all
Any idea on fuel in and out pipes maybe pipe clogged
Would appreciate some help to get this started up…
Thanks
Bleeding the fuel system used to be so straight forward, but this could be what you need to do:
https://moba.i.daimler.com/baix/trucks/963_hmi-classic_2019_a/en_GB/page/ID_d451d4f47f2667c2ac190d2b3c935a4b-d69989c87f2667d1ac190d2b5a788693-en-GB.html#
Well…
Come on, what happened?
Don’t keep us all in suspense.
Today’s lesson
When yellow fuel light comes on , go and put some diesel in [emoji6]
Fuel light roulette is a game you don’t always win [emoji23][emoji23][emoji23]
Sent from my truck
blue estate:
Today’s lesson
Sent from my truck
Or you could put some in before fuel light comes on as I keep telling the mrs
Spray some easy start/brake cleaner into the air intake whilst cranking it over.
If you do this on your own, you will need long arms :slight_smile:
Fill fuel filter then try it. Just hard when its got air in pipes
I alwaus fill up at a quarter tank.No point pushing my luck
Suedehead:
NO--------id never let that happen to my engine
blue estate:
Today’s lesson
Sent from my truck
Get with the programme - E stands for enough.
ringfur:
Suedehead:
Works though :stuck_out_tongue:
