Could someone help me work out a schedule of Saturdays and Sundays I could work from the 9th of September through to the 23rd of December legally ?
I work a non driving job Mon to Fri 08.30 till 17.30 1 hour break per day.
Every 3rd sat from 08.30 till 12.00.
My next Saturday in is the 2nd of September.
I have class one work and it starts Saturday the 9th of September.
I need to pay a large debt off and work is the only way to do it before it gets out of hand .
Basically you will legally be able to work one shift every second week.
Apart from any holidays you have you will not legally be able to work Saturday and Sunday in the same weekend.
Thanks for that .
Would I have to do a manual entry for the days I’ve worked in the week ?.
use a name:
Thanks for that .
Don’t put manual entries into the tachograph to cover your week job, it will be time consuming and there’s a possibility of mistakes, apart from that it’s just not necessary.
Legally, in weeks that you drive in-scope of EU regulations you should record your normal jobs hours on charts or printouts or a manual entry into the tachograph (see above), you just need to write the start and finish times and your name then sign it.
The easiest way has to be to write the records on a piece of printing paper then sign it, it’s only to show that you’ve had the required daily rest period before starting the driving job and also to show that you’ve complied with the weekly rest requirement, you can throw the records in the bin after 28 days.
