I’ve got a 2017 TGX with the touchscreen multimedia system. I’ve had no problems using it… until today.
Radio was on and working fine. I switched off for my afternoon nap. When I started up again the radio wouldn’t work. Everything else; sat-nav, phone, playing music via Bluetooth etc is working fine… just no radio. Where it used to say the preset station names, it’s now just six blank spaces.
Halp meh!
Contraflow:
Halp meh!
Have you tried going into the setup menu and doing a “factory reset”?
MAN electronics not working, get used to it id say.
I swapped my brand new one for a 2 year old volvo when work gave me the choice.
Can you store new stations on the presets? If so, probably a faulty internal battery. If not, probably a tuner or aerial fault. If you can’t be arsed, just use the station list button and select what you want.
Nope, list is empty. Can’t do anything with it.
[zb]ing piece of [zb] is only six months old.
Contraflow:
Forgot to ask about manual tuning, can you do that? TBH, I doubt it would matter if you could. Its sounding like a workshop job either way.
Contraflow:
Halp meh!
You tried the kill-switch at battery for couple of mins??
This one does similar every once in a while but a factory reset cures it.
Sent from my SM-J500FN using Tapatalk
I’ve noticed…
That the steering wheel controls for the radio stop working after a few hours with these new touchscreen MANs.
Ok, not a job stopper but signs of poor quality build which MANs are famous for.
So today I parked in the same layby that I had my afternoon nap in the other day when it stopped working.
When I woke up and started up again, the radio came back to life. Strange. It’s either a coincidence or that layby disables and enables my radio.
Contraflow:
Your boss has a spy camera fitted and he’s playing with your head.
Contraflow:
Fylingdales is probably behind the bush
