Iveco stralis unit rear spot lights issue
Hi all, new in group just got a iveco stralis, unit spot lights fitted rear of cab , we use for when couple trailer , won’t work , light on button in cab turn on but no life in wire , any one had experience, thanks in advance .
Jav
Did you tr it with headlights on the could get feed from there. Gerbil
Yes mate , tried to trim on headlamps , rear gear everything but nothing no show even life in wire, all fuses are fine .
Change the bulb?
MD & GERBIL
That’s new led light smd , there is no life there in wire . Can someone know where wires are connected mainly
If the feed to the light on the light has no power, then we can ignore the bulb/LED etc.
So which fuse is the rear light fitting on?
If that is live on both sides when switched on, then there must be a break in the wire.
If not live at the fuse you need to go back to the switches. If they make/break correctly then the wiring between there and the fuses is broken.
Same applies to any relays fitted.
You need a wiring diagram and meter (or bulb and wire) at the least. And need to systematically see where there is and isn’t power and narrow it down to one component/ section of wiring.
I can’t see any short cuts. Check each component and section of wire.
