Without doubt introducing the upgraded vehicle requirements for driving tests has made it harder to pass the test.
Our company held on to two rusty old trucks for a few years when we really wished we could have used the newer (range change) trucks often sat in the yard doing nothing but these old ones had ‘car like’ gearboxes and thus easier to drive for novices and had a better pass rate with hard to teach drivers!
Of course some individuals can handle a range change with only a few wise words and never make it look hard work. However most other people can take 2 or 3 days to get used to it, this all costs money and we now do far less 4 day courses than we used to. So Our pass rate hasn’t changed much but its more expensive now.
Common mistakes/failures include:
Forgetting to select low range when setting off and thus trying to move away in either 7th or 8th and possibly holding up traffic. Whenever you stop choose low range when you move the lever to neutral.
Completely getting in a muddle at seemingly random times, forgetting where any gears are and what gear is required. Usually because something has leaped out the tarmac and put off the poor novice. Hopefully before the test new drivers get out of this annoying habit but the stress of the test can let it rear its ugly head again!
The gear change exercise is harder with an 8 speed, drivers may choose the wrong gear coming down the box - like 3rd instead of 1st or resume normal driving in high range by mistake. The straight 6 was easier but you could still get the wrong gear and 1st was possibly harder to find because the ratio difference between 2nd 1st was larger. On an 8 speed the difference between gears is less which makes having the correct road speed and engine rpm less of an issue (gears go in easier).
Trying to use all the gears to slow down is not seen as the modern technique, failing to come down the gears 8-6-5-4 or similar may cause test minors or a serious. Gears are for going and brakes (not gears) are for slowing! Not my opinion - the DSA’s.
Don’t bother trying to change to 5th gear on a small roundabout unless your very good, you will find yourself trying to steer with one hand on the wheel.
Setting off in high range on the hill start up or down exercise is another favourite.
I dare say I could go on.
Myself, when I learnt I just got told its a 4 over 4 gearbox here is the switch, off you go fella! I soon learnt.
Oh, and I’m not a fan of the slap over gearbox found on Renault and recycled U-Boats (mercs), they are simple but why should you do 3 lever movements instead of 2. Check out what your driving school can offer.
Example - changing from high 5 to low 4th:
Slap over -
- Move lever to neutral
- Slap lever to the left and let centralise
- Pull lever back for 4th gear.
Range Change -
- Flick switch as you put lever in neutral
- Select 4th gear (right and back)
