Iceland Food Ltd,Swindon
need directions to the Penzance Drive w/house please.will be coming down from Leicester,have no sat.nav.,and google maps appear to take me through the town.any help would me much appreciated! :slight_smile: i think my trailer height will be 15 ft 3 in.
come off M4 junc 16 head towards town centre A3102, at second roundabout turn right staying on A3102 bear off left just before railway bridge if I remember there is a set of lights there and Iceland is up that road on the right hand side :sunglasses: :sunglasses: :sunglasses:
correction its on the left brain freeze
wildfire:
thank you very much :slight_smile:
CLICKY The entrance is a bit closer to the Wooton Basset Road than where the ‘pin’ is.
Personally I’d do M1-A43-M40-A34-A420-A419-M4-A3102 and is the way I’ll be going on Tuesday for a 11:30 tip then on to Enfield for a 18:30 tip.
MADBAZ:
thank you-14.00 tip on monday :slight_smile:
that is the long way round, but definitely the easiest way to follow. when coming down the a419 exit at the turnpike junction, take a right to go across the north of swindon, past asda - walmart, then keep following that road straight,until you get to sainsbury’s, take a slight left, and then at the end of the road, take a right and you can’t miss the iceland rdc.
carryfast-yeti:
MADBAZ:
You’ll still be there at 1700…
Whatever happens don’t be late…otherwise you’ll be sin binned by jabba the hut’s uglier fatter sister at the desk.
DonutUK:
carryfast-yeti:
MADBAZ:
Would i be the only one on here too go M69-A46 A429-A4I9 from Leicester to Swindon.?
quote]
[/quote]
Yeh, that’s the way to go, do that route a fair bit, done all the different ways and this in my opinion is the best.
Madguy :smiling_imp:
madguy:
quote]
[/quote]
Use to go M69 M40 jn15 the A419 all the way
nick2008:
madguy:
quote]
[/quote]
Sorry a little confused here, M40 jct 15, then A419 all the wayâ– â– ?
Are you sure about that??
Maps are cheap enough you can get the whole of Wiltshire for £6
Suedehead:
That’s the route I use coming back from Leicester, unless I’m really heavy in one of Satans jokes (Daf CF…spit :imp: ]. Keeping legal there is only about 10 minutes between the 2 routes but distance wise about 60kms and I do like a bit away from the motorways at times. depending on your break times there are about 3 snack bars between the M40 and A419 and services at the A429 junction with toilet.
Carryfast-yeti. What chamber are you delivering to? Shift change at 15:00 so don’t expect any trailer action between 14:40 and 15:20, that would be on a good day, and take the left hand lane through the gate please. :sunglasses: :sunglasses:
hitch:
You could probably buy the whole of Wiltshire for £6 :stuck_out_tongue: :laughing:
Wiretwister:
Suedehead:
no idea what chamber.don’t normally do this type of load,it’s bottled water i believe.
DonutUK:
carryfast-yeti:
MADBAZ:
arrived at 12.55,tipped and on way home 13.30 :smiley: thanks for the directions,spot on :sunglasses:
