Some times it’s not selecting a gear while upshifting in even numbers (odds are fine)
Same as when it down shifts doesn’t select even numbers sometimes
Anyone had the same problems? If so what was issue
Scott M:
Started with a little Gearbox issue today
It’s 470k the box
Possibly whatever the I shift uses instead of the old splitter switch/actuator system.IE no high splits going through ?.
Scott M:
New box and clutch the selector broke for the even gears
how much?
£8.5k - 3 years warranty if done by a dealer…
hmm not cheap…but till yesterday i didn’t know renault has ishift…even i was suspicious…
What could cause this? ishift is supose to be best box out there…
Scott M:
how much?
The I-shift is the best out there [IMO], but like everything, they can go wrong
I got mine turned round in 24 hours, which was pretty impressive in this day & age, and with the 3 year warranty, I got peace of mind on the box & clutch front going forward…
