One of our 7.5 ton tippers can handle easily a couple + more ton than at present legal allowed to carry (we have proved this on private land as well,of course).the springs according to my fitter are already heavy duty .The lorry already has high sides ala ■■■■■!
Can anyone please tell me?
1; What do we have to change on the lorry,is it Springs front and back, wheels and tyres? anything else? brakes??
2; What else with VOSA?
3; Do our ordinary licence drivers need an HGV licence or are they just allowed to carry the legal limit for 7.5 ton payload as before the uprate or indeed are they not allowed to drive it all now??
Look forward to your replies costs and hassle might not be worth it?
Tricky Dicky:
If the drivers have pre 97 C1 and you up the trucks to over 7.5 tonnes then they will need a C to drive them
They will not need to do the INITIAL driver cpc - just the ‘normal’ theory tests and the practical road drive.
Its design weight will dictate its max permissable plated weight(should state it on the plate cert), and if you do plate it for higher weights, the licence catagory for the higher weight will be required for the driver at all times wether fully utilsed or not.
If its current design weight is not what you want, probably a lot cheaper to change the truck for one of the required weight catagory than give your mechanic a load of work.
Big Joe:
Seconded. There’s plenty out there and if not, its a doddle to take off a flatbed body and bolt on a tipper one.
Big Joe:
not many ten tonners about on market the few about make strong money
Different vehicles will have different requirements to uprate them,it depends on what individual items are rated at.For example,on a firm I worked for,we had a Mercedes 3.5 tonne rated motor that was uprated to 4.5 tones simply by fitting uprated rear springs,everything else was within the load rating.
I suggest specialist advice is needed from the vehicle manufacturer.
Any uprating will require a retest and replating.
