I got a IN10 and 6 points in June 2009.
Am I right in thinking it’s 3 years?
Or is it 4?
I’ve just copped another 3 points for jumping a red light so I’m on thin ice,unless I can negotiate some sort of course attendance rather than accept the 3 points.
It stays on you licence for four years from the date of the offence but 3 years for totting up.
as coffeeholic says, on licence for 4 years, but only need to declare it for 3 years
4 years. I have one on my license and it expires in January. Yippee.
Just in case you have anymore
AC10 to AC30 must stay on a driving licence for four years from date of offence.
AC10 Failing to stop after an accident
AC20 Failing to give particulars or to report an accident within 24 hours
AC30 Undefined accident offences
BA10 and BA30 must stay on a driving licence for four years from date of offence.
BA10 Driving while disqualified by order of court
BA30 Attempting to drive while disqualified by order of court
CD10 to CD30 must stay on a driving licence for four years from date of offence.
CD10 Driving without due care and attention
CD20 Driving without reasonable consideration for other road users
CD30 Driving without due care and attention or without reasonable consideration for other road users
CD40 to CD70 must stay on a driving licence for eleven years from date of conviction.
CD40 Causing death through careless driving when unfit through drink
CD50 Causing death by careless driving when unfit through drugs
CD60 Causing death by careless driving with alcohol level above the limit
CD70 Causing death by careless driving then failing to supply a specimen for
CD80 and CD90 must stay on a driving licence for four years from date of conviction.
CD80 Causing death by careless, or inconsiderate, driving
CD90 Causing death by driving: unlicensed, disqualified or uninsured drivers
CU10 to CU80 must stay on a driving licence for four years from date of offence.
CU10 Using a vehicle with defective brakes
CU20 Causing or likely to cause danger by reason of use of unsuitable vehicle or using a vehicle with parts or accessories (excluding brakes, steering or tyres) in a dangerous condition 3
CU30 Using a vehicle with defective tyre(s)
CU40 Using a vehicle with defective steering
CU50 Causing or likely to cause danger by reason of load or passengers
CU80 Using a mobile phone while driving a motor vehicle
DD40 to DD80 must stay on a driving licence for four years from date of conviction.
DD40 Dangerous driving
DD60 Manslaughter or culpable homicide while driving a vehicle
DD80 Causing death by dangerous driving
DD90 Furious driving
DR10 to DR30 must stay on a driving licence for eleven years from date of conviction.
DR10 Driving or attempting to drive with alcohol level above limit
DR20 Driving or attempting to drive while unfit through drink
DR30 Driving or attempting to drive then failing to supply a specimen for analysis
DR40 to DR70 must stay on a driving licence for four years from date of offence.
DR40 In charge of a vehicle while alcohol level above limit
DR50 In charge of a vehicle while unfit through drink
DR60 Failure to provide a specimen for analysis in circumstances other than driving or attempting to drive
DR70 Failing to provide specimen for breath test
DR80 must stay on a driving licence for eleven years from date of conviction.
DR80 Driving or attempting to drive when unfit through drugs
DR90 must stay on a driving licence for four years from date of offence.
DR90 In charge of a vehicle when unfit through drugs
IN10 must stay on a driving licence for four years from date of offence.
IN10 Using a vehicle uninsured against third party risks.
LC20 to LC50 must stay on a driving licence for four years from date of offence.
LC20 Driving otherwise than in accordance with a licence
LC30 Driving after making a false declaration about fitness when applying for a licence
LC40 Driving a vehicle having failed to notify a disability
LC50 Driving after a licence has been revoked or refused on medical grounds
MS10 to MS90 must stay on a driving licence for four years from date of offence.
MS10 Leaving a vehicle in a dangerous position
MS20 Unlawful pillion riding
MS30 Play street offences
MS50 Motor racing on the highway
MS60 Offences not covered by other codes As Appropriate
MS70 Driving with uncorrected defective eyesight
MS80 Refusing to submit to an eyesight test
MS90 Failure to give information as to identity of driver etc
MW10 must stay on a driving licence for four years from date of offence.
MW10 Contravention of special roads regulations (excluding speed limits)
PC10 to PC30 must stay on a driving licence for four years from date of offence.
PC10 Undefined contravention of pedestrian crossing regulations
PC20 Contravention of pedestrian crossing regulations with moving vehicle
PC30 Contravention of pedestrian crossing regulations with stationary vehicle
SP10 to SP50 must stay on a driving licence for four years from date of offence.
SP10 Exceeding goods vehicle speed limits
SP20 Exceeding speed limit for type of vehicle (excluding goods or passenger vehicles)
SP30 Exceeding statutory speed limit on a public road
SP40 Exceeding passenger vehicle speed limit
SP50 Exceeding speed limit on a motorway
TS10 to TS70 must stay on a driving licence for four years from date of offence.
TS10 Failing to comply with traffic light signals
TS20 Failing to comply with double white lines
TS30 Failing to comply with ‘Stop’ sign
TS40 Failing to comply with direction of a constable/warden
TS50 Failing to comply with traffic sign (excluding ‘stop’ signs, traffic lights or double white lines) 3
TS60 Failing to comply with a school crossing patrol sign
TS70 Undefined failure to comply with a traffic direction sign
TT99 must stay on a driving licence for four years from date of conviction.
TT99 To signify a disqualification under ‘totting-up’ procedure. If the total of penalty points reaches 12 or more within three years, the driver is liable to be disqualified
UT50 must stay on a driving licence for four years from date of offence.
UT50 Aggravated taking of a vehicle
Aiding, abetting, counselling or procuring
Offences as coded, but with 0 changed to 2 eg LC10 becomes LC12.
Causing or permitting
Offences as coded, but with 0 changed to 4 eg LC10 becomes LC14.
Inciting
Offences as coded, but with the end 0 changed to 6 eg DD40 becomes DD46.
Bloody hell Rew, are you “having a moment”, or are you in rehab after being released from your waterboarding torment at amazon
Don’t you have to declare for 5 years or is it just my insurance company
Yes most insurance providers expect declaration for 5 years history. But it only stays on license for 4
xahara1272:
Had that discussion with the broker the other day.AnSP30 that came of in April is still counted by the insurance company.
Just another racket to get more money out you.
xahara1272:
You only ever answer the questions on the proposal form, if you volunteer anything more, you will end up paying more or failing to be covered which is much more serious if you are ever refused insurance.
Some ask for 3 years history, some ask for 5, some of the specialist ones may even want 10 years history. In my experience cheap insurance is anything but!
Coffeeholic:
Having had my fair share of points in the past (more than the allowed limit ) I can tell you that the 4 years thing is an urban myth. If you apply for a new licence after “losing” your old one or change address between 3 and 4 years of the date you got the points, it will come back with them removed.
Interesting. I was going to wait till January to send my license for upgrade (once I pass). But I won’t need to hold out now. Cool
Double post. Sorry.
Rob K:
Coffeeholic:
It stays on you licence for four years from the date of the offence but 3 years for totting up.Having had my fair share of points in the past (more than the allowed limit
I have 6 points that are between the 3 and 4 year period so I might try that out of interest to see what happens.
