HELP ! with gearbox
Hi all
Could someone help we with this problem, I am emigrating to New Zealand in about 6 months time but alot of jobs state must have experience with Road Ranger gearbox, The job i looked at uses an Eaton Fuller 18 speed Road Ranger, Now is this 6 over 6 with splitter in high box or something different, I have used all types of gearboxes in UK so is there something on par we use here so i have an idea.
Thank you
Tony
Heres a link to a video which may be helpful :
Clickety Click
I think thats the one :blush:
Oh FYI they aren’t as scary as ya think :laughing: Once you get the hang of it you’ll love it :wink:
I think it is a 4 over 4 with split in all ranges and a split on the crawlers. The same set up as the Renault B18 but constant mesh.
Roadrangers used to be in the old Daf 2800s sometimes. 4 over 4 with split on High range is normal.
Don’t stress too much 'Junky !!
If you can get someone to show you the basics of a Road Ranger gearbox you are home and hosed.9,10,13,15,15O/D and 18 speeds are all the same.
18 speed is a 4 X 4 with splitting and a range switch,e.g. 1st split 2nd then move stick into 3rd split 4th move stick into 5th etc then select hi-lo button to next range and repeat upto 18.
15 speeds you only split lower box etc.
Its all in revs driving clutchless,or double cluthcing,and like riding a bike once you have mastered it you will wonder what all the fuss is about.
Boots
boots:
Boots
It sounds simple enough i found the eaton twin split easy to use and the range change plus split with 12 or 16 gears are very common here and are easy to use so i guess i will cope alright.
Thanks for help all.
Tony.
It is just practice mate, I know of old hands that still crunch them and miss gears.
I hate them, but on the odd occasion I have to drive one I prefer not to use the clutch ( whistling or singing as change gear seems to help ).
Keep looking mate, theres a few companies around that don’t have them.
