Hello, believe this is my first post … and one hell of a post its gonna be.
I was stopped by VOSA yesterday for a spot check (was told it was VOSA routine check). I was told I was stopped because the trailer ride height was high, which ok it was high. I told the guy that I had pulled the control to self level the ride height before commencing my journey and explained that whatever was causing this has happened during the journey. To cut a long story short it turns out that the bracket holding the self levelling valve (not the handle you operate the suspension with) had badly corroded and broke away from the chassis causing the suspension to be jacked in the air.
The examiner put an immediate prohibition on the trailer (fair enough, it was dangerously hanging there), and commented saying it was a maintenance issue (i.e not my fault). He went to do the paperwork and came back shortly after to ask for my licence again. He said “The computer is telling me I have to issue a fixed penalty”, so I asked how much etc, and was told your company should pay it because its not your fault.
A good while later … nearly an hour … he called me over and said there was some paperwork to finish off, so went into the office, read a caution and asked questions regarding the trailer … what do you think caused it? was it ok on your walk around check? do you check under the trailer during the check >? >> WHAT !!! I visually check with a torch, but by no means do I deem my self qualified to go crawling under the trailer?? He then explained the fixed penalty, explaining that it is endorsable and to send my licence off, and if I want to appeal that I need to take it to court.
I have been fined and will have points on my licence for an issue that even he agreed was down to maintenance! I understand I was in charge of the vehicle but honestly not long noticed the trailer skipping a little on the the last two roundabouts, about 600 yards apart. I was honestly intending to stop and check to see what problem I had, they just beat me to it.
SO … what I need advice on is … Have a got a good case to take it to court? Vehicle was ok during checks. My argument would be that I am not a qualified or competent fitter and so, as far as I am concerned due to health and safety, should not be crawling under the trailer … a visual check between the road wheels into chassis was made. Another issue I have thought about is that, Am I right in saying that VOSA do no longer exist (changed to DVSA in April), so given that I was handed paperwork with VOSA on it and told that it was a VOSA check, would it make it void?
Finally I am not condemning the actions of the examiner, he should me what was wrong, and I agree it was dangerous, however given that this happened during the journey and as he clearly stated “was a maintenance issue” I feel hard done by that I was lumbered with the fine and more worryingly points which will have a knock on affect with my car insurance
Rant Over
